What is this cutter?
Geerbangr
Jun 21, 2017
64
Facemills that use perfectly square inserts won't mill to shoulder, not that I have seen anyway. You would need some kind of relief on the insert.
Yup, inserts are square but if you look closely, you wouldn't be able to mill to a shoulder. The inserts are rotated slightly for clearance. If the inserts were oriented so you could mill to a shoulder, because the inserts are square, you would get full contact on the insert when facing, that would lead to a number of issues.
This was in with the mill I bought. What's the value of it? I can get some close ups of the blades. I'll have to find a YouTube video on how to use it properly.
I use mine like a fly cutter. Im sure someone will be along to help you with what inserts it takes form what I've seen there are a million types of inserts....
You could try to figure out the insert you have from this information. You will need to take measurements of the insert. I know with lathe toolholders they typically put the number of the holder on it, and sometime the insert. Not sure about tooling for the mill though.
http://www.carbidedepot.com/formulas-insert-d.htm
Hth
Rich
