What is meant by "backed off" or "backing off" cutters?
HMF
Site Founder
Administrator
Sep 22, 2010
7,223
Hey Guys.
Another dumb question from dumb Nelson,
What is meant by "backed off" or "backing off" cutters with respect to a milling cutter, and what is the purpose of it?
Thanks!!
Nelson
It has something to do with relieving the angle behind the cutting edge so that it does not rub. Rather like front rake on a lathe tool.
That was the explanation I saw elsewhere, and frankly, it makes no sense to me, so I was hoping one of you guys could explain it better.
Thanks,
Nelson
Re: What is meant by
The term "backing off" or "relieving" is used for some types of milling form cutters such as an involute gear cutter. If I have done it correctly the attachment is the US Patent #817885 showing how such a form cutter can be relieved or backed off in a lathe.
Regards, Benny
In middle Tennessee USA
  • Patent 817885 - Taylor Relieving Attachement for Lathe.pdf
I was wondering the same thing last week. Here's one of the videos I found.
[video=youtube;PTZBSlNyKi4] http://www.youtube.com/watch?v=PTZBSlNyKi4 [/video]
Watch the tool holder as it starts each cutting tooth at full height and takes a bit off on a slope toward the back of the tooth. As has been said, it stops the trailing part of each tooth from rubbing on the work.
