What do y'all think about this ?
On my 9 SBL, mine has the star wheel, I'll stop the feed just shy of hitting the shoulder. I've never had the clutch to lock up and not dis-engage. One thing I recommend, is not to engage hard when engaging. Just gently engage the lever till it grabs and feeds. Not sure if the lever type is adjustable, maybe bac1972 can enlighten us a little.
Mine has the star wheel, so you are using the clutch to stop the feed?
With the factory design (referring to the diagram below), the slip torque is adjusted by loosening a setscrew (thru hole "U"), rotating the swivel nut ("S"), and re-tightening the setscrew. Once the torque is set, the radial position of the lever is adjusted for operator preference by loosening a setscrew ("O"), rotating the lever to the desired position, and re-tightening the setscrew: http://www.wswells.com/data/parts/2003.pdf
I understand the clutch, how do you stop to a shoulder when turning, disengage the power feed, disengage the belt, or disengage the clutch?
I definitely use the clutch and stop short and finish off the shoulder last. If you stop the belt you risk cutting tool breakage. I also have a variety of adjustable stops if I'm doing something critical. South Bend makes a few different ones you can usually locate used. I have a micrometer one on there now that I use the most. This video is long but worth watching. There is also a book version out there.
Thank you. The video is helpful. The clutch handle on this one has been tightened so much that I could not budge it with just my hand. I may need a strap wrench to loosen it.
Thank you again.
Thank you. The video is helpful. The clutch handle on this one has tightened is much that I could not budge it with just my hand. I may need a strap wrench to loosen it.
Thank you again.
You're welcome...glad I could help.
Y'all might be interested in this one. The original thrust washer appears to be hardened material and should be good for the application, but I happen to have ball bearing thrust bearing set that happen to fit perfectly. I bought these a couple of years ago for a project that I never started. To keep the nut from unscrewing itself I just put a couple of drops of 246 Locktite. 20170708_215122.jpg 20170708_215145.jpg 20170708_215254.jpg
