- Jan 16, 2017
- 19
Ok thanks, this form is really helpful, another question is why does it has 3 different grinds on it, and it has a side adjustment screw? I'm guess the anvil is just mild steel, I almost tried to cut a grade 8 bolt with the anvil to just try it out my new toy, I'm guessing it wouldn't of worked out goodThe anvil sets the helix angle at which the the threading insert sits at. The anvils are available in different angles. Don't worry about, just install the insert on top of the anvil. Unless you are threading very coarse pitches, the standard anvil that usually comes with SER holders will cover a wide range of threads.
That's a shim in the tool. Very important that you don't lose our damage it!I bought this insert tool off eBay and want to know what kind of insert this tool has on it so I can buy a couple spares, I have only used hss so insert tools are new to me
Thanks Dustin
