What are these?
autonoz
Oct 19, 2012
456
Can someone tell me what these are used for? 1. Says chucker bushings 2. No idea 3. Some type of clamp or hold down
Picture #1 I do not know. Unclear without a better look.
Picture #2 they appear to be locating buttons, tool maker buttons etc
Picture #3 hold down clamps like what you would use on the milling table for example.
Picture #1 some sort of reducing bushings. Presumably for some sort of chuck/collet. Is there a manufacturer's name on the lid of the case?
Robert D.
#1 Likely bushings for a chucker lathe for mounting fractional drills in the turret. What diameter is the OD of the bushings?
The OD is .625
The top of the box says "RMS Supply Inc. Tempe Az. Patent pending"
The slot is for the set screw to pass thru and press on the tool in the bushing.
did you find out?my boss has me listing these as hardinge chucker bushings on ebay,but i googled hardinge chucker bushings,images,and they dot match up.
