What are the proper materials for making punches?
HMF
Site Founder
Administrator
Sep 22, 2010
7,223
In order to make a Center punch and a prick punch what type of steel should be used- drill rod, tool steel, 4130?
And what is the proper procedure for hardening the end?
Thanks,
Nelson
Old worn out taps can be ground to make a very nice centre punch.
If you are starting from scratch, you are best off using one of the tool steels (Drill Rod) that can be hardened. Available in Air, Water or Oil hardening
Walter
D. U., a drill rod for punch post with accurate steel & heat treat info. Good write-up.
If I were making one, I'd prefer O1 cause I'm more use to the "home" heat treat results.
