    Dismiss Notice
wet carpet cutting tool
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by John_Dennis, Sep 5, 2017.
  1. John_Dennis
    John_Dennis United States Active User Active Member
    33
    28
    City:
    Houston
    State:
    Texas
    -Return to Top-
    I attempted to make a tool to cut wet nasty carpet out of flooded homes. It worked a little but tents to clogged with fibers.
    I am sure this could be much improved, I am looking for something quick and simple as I want to make several.
    brino likes this.
  2. GoceKU
    GoceKU Macedonia Active Member Active Member
    342
    63
    City:
    Kumanovo
    State:
    Outside US / Canada
    -Return to Top-
    You have the right idea, but it needs to be one piece, i'll advice make one from a leaf spring or an old wood saw blade, i'll attach a picture of a good design.
    eric.grulke.79 and John_Dennis like this.
  3. kvt
    kvt Active User Active Member
    667
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    +1 the knife needs to be one solid piece. Either welded in, or made in. Yea, a pain to sharpen but a good file or stone will do that. Think if something like the sickle in the horror movies. Sharp tip, and a long curved cutting bade. And they can be very sharp.
  4. francist
    francist Canada Active User H-M Supporter-Premium
    678
    93
    City:
    Victoria
    State:
    British Columbia
    -Return to Top-
    -frank
    rdean likes this.
  5. brino
    brino Active User H-M Supporter-Premium
    2,298
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    francist likes this.
  6. kvt
    667
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    brino I can see that, but the hook on the opposite side to pull the carpet up with. This way you can pull it up a little cut into chunks and pull them out of the way without having to get down in the muck
    brino likes this.
  7. Superburban
    Superburban United States Active Member Active Member
    202
    43
    City:
    Grand Junction
    State:
    Colorado
    -Return to Top-
    How about something that holds the hook style utility knife blades?
  8. Hawkeye
    Hawkeye Canada Active User H-M Supporter-Premium
    392
    83
    City:
    Kelowna
    State:
    British Columbia
    -Return to Top-
    If you grind a thin slot into the hook on your tool, so that the end of your blade fits into the slot, it should prevent the jamming you are getting. Then the blade is still replaceable as you have designed.
  9. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,329
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    If the carpet is really old, get a cut started and pull! Should rip into strips making it easy for removal, even soaking wet.
  10. Eddyde
    Eddyde Active User H-M Supporter-Premium
    437
    63
    City:
    Brooklyn
    State:
    New York
    -Return to Top-
    +1 on the hook style utility knife blades, they cut carpet like butter and stay pretty sharp. You can even resharpen the blades with a small cylindrical stone, saves having to change them as often.
    eric.grulke.79 likes this.
  11. grumpygator
    grumpygator United States Global Moderator Staff Member Director
    740
    113
    City:
    tellavast
    State:
    Florida
    -Return to Top-
    Use your hook to pull it off the tack strip and over on top of itself than cut through the backing.
    When I strip carpet I go with 3' wide strips rolled up and stacked at the curb. Here in Florida the carpet company's pay for the old padding ...not much but better than throwing it away...
    **G**
  12. Silverbullet
    Silverbullet Active Member Active Member
    879
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    It would be better with a revolving sharpened cutter. Round blades could cut down on the bunching of straight cutters. An old pizza cutter blade sharpened and bolted but not tight.
  13. John_Dennis
    33
    28
    City:
    Houston
    State:
    Texas
    -Return to Top-
    I notched the hook with a dremel as Hawkeye suggested and it works well now.
Share This Page
