Westinghouse 1 Hp Grease
Al 1
Sep 11, 2011
259
Hello, I am in the process of cleaning / painting / repairing 10" south bend.
The motor has two grease access plugs on each end.
I removed one and could see inside. There are a few squiggles of grease in there.
As far as I know most electric motors, especially vintage ones take oil not grease.
My (1964) Machinery's Handbook just says to purge the old grease out through the drain hole and apply new. Doesn't specify what type to use though.
-frank
as mentioned above, vintage/antique motors used mostly oil for lubrication
the motor you have shown is modern enough to have had grease packed in the bearings, hence the end grease cap .
you can safely use a lithium soap or a lithium complex grease in your motor.
many manufacturers make the greases- Sta-Lube, Mobil, Shell, Phillips, Super-Tech (a Walmart brand), Traveller (a Tractor Supply Co. brand), Kendall, Valvoline, etc
lithium complex greases can take higher pressures and heat than the soap counterpart, but both would be acceptable regardless.
another thing to remember, you do not want to overfill a bearing, doing so will adversely affect the operation and longevity of the bearing.
there is a formula for the filling of a bearing believe it or not:
G = 0.114 x D x B
G= grease (in ounces)
D= bore diameter (in inches)
B=bearing width (in inches)
Frank is on tract, take the bottom plug out, run the motor until warm, I have read about two different ways to grease the bearings, 1) fill the top opening with grease until it forces the old grease out the bottom. Leave the bottom open and run to allow any extra grease to leak out, or 2 Open the bottom drain plug, just put "some" grease in the top opening, run the motor with bottom open to allow any excess grease to drain. Clean up any mess, replace the plug and your done
I found a maintenance manual for GE motors, it said to regrease the motor every 10 years. I found a Westinghouse manual, use POLYUREA grease and regrease every 7 years.
see page 8 for lubrication
http://www.tecowestinghouse.com/manuals/TWMC Instruction Manual_143 to 449 frame.pdf
Ulma Doctor was posting while I was typing, I'd go with his formula for the correct amount of grease
Well I learned something here too! I did nut know that some motors take grease. How could I not know that? Just seems like all the motors I have ever had took oil, lol.
a lot of the old motors used bushings made of babbitt, bronze, or oilite bushings and were (relatively) low speed motors.
all these bearing(bushing) materials function well with oil as the lubricant.
when the motor speeds started going up, the manufacturers started using roller bearings in the motors for both efficiency and longevity at greater speeds.
generally speaking, typical electric motors use roller bearing construction now- but most are lifetime (of the bearing) lubricated- without provision for external lubrication.
nowadays the better manufacturers will have grease zerks to pump up
If you can't find the Polyurea grease use a #1 lithium base grease. Add a permanent zerk to the top port, remove the lower plug and add a couple "shots" then get the motor hot / run for at least 30 minutes. Then re-install the lower plug. Depending on the amount of run time - you probably only need to add grease every other year. If you run it a lot (like every day for 8 hours) then you'd need to add each 12 months.
Otherwise, do it every other year.
