I would be the next onei'd be the first one in line if they made them
You can get aluminium welding electrode for stick welders so I don't see why you shouldn't be able to get a flux core electrode. But I think you would still need an AC power supply. DC doesn't work for aluminum welding - well not unless you have a very hi-tech welding machine (at work we had a subcontractor come in and their assemble team used DC MIG aluminum welding but it wasn't you standard DC MIG power supply, looked very expensive)
I have used stick and oxy/acet on aluminum with varying results my Lincoln mig 110 supply with spool gun is ok on thin material but the 220 machines are great for heavy material. Mig on aluminum is done with ( dcep) direct current electrode positive, mig machines with pluse settings are great for thin material and position work. I haven't used or seen cored al mig wire, would be great if it worked.You can get aluminium welding electrode for stick welders so I don't see why you shouldn't be able to get a flux core electrode. But I think you would still need an AC power supply. DC doesn't work for aluminum welding - well not unless you have a very hi-tech welding machine (at work we had a subcontractor come in and their assemble team used DC MIG aluminum welding but it wasn't you standard DC MIG power supply, looked very expensive)
