- Dec 12, 2011
- 46
Another dumb newbie question.
I'm making weld nuts that need to protrude 1/4" on either side of an 1 1/4" square tube which gives me an area to weld the nut to the tubing.
I'm using two 2" sections of 1" cold rolled steel.
I need to drill and thread them for a 1/2-13 rod end. My chart says I need a 27/64th hole for the tap.
I was thinking the easiest way to do this is face one end on my lathe (the other end doesn't matter), then drill a small hole (say 1/4) followed by the 27/64 drill (also using the lathe).
Is this the right way?
