  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
Wear Issues
Discussion in 'GENERAL DISCUSSIONS' started by dirty tools, Jan 6, 2017.
  1. dirty tools
    dirty tools United States Active User Active Member
    15
    18
    City:
    Fort Lauderdale
    State:
    Florida
    How do I measure the lead screw for wear?
    I don't know if the lead screw has worn of it the gears in the apron are work and need replaced, or both.
    it is on my 1916 SB 13 X 5 great machine.
  2. Tony Wells
    Tony Wells United States Vice President Staff Member Administrator
    19,032
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    What symptoms are you experiencing? Usually you can take measurements way out near the outboard end where it sees virtually no use and should be as good as new.
  3. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,176
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    With the half nuts engaged with the lead screw, set it for let's say 8 threads per inch. Set you up a 1" travel indicator to indicate carriage travel, mark you a point on the chuck that would be at 12 O'clock position or what ever, so there is a reference point to stop at. Make sure the slack is out of the half nuts and lead screw, mark "zero" on the 1" travel indicator. Rotate the spindle 8 times and stop rotation on the reference point at 12 O-clock position. Take reading on your 1" travel indicator. It should read 1.000" If not, the difference will be the lead error in your lead screw. I would suggest doing this for several inches starting at the headstock and advancing out toward the tailstock for about 12-18" or more. Record each reading to establish a pattern of wear in your leadscrew. A worn gear train will not create lead error, only if the lead screw is worn. Ken
  4. dirty tools
    15
    18
    City:
    Fort Lauderdale
    State:
    Florida
    the hand wheel has to be very lightly held in direction of travel.
    The half nuts are adjusted properly
  5. 4gsr
    1,176
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
  6. chips&more
    chips&more United States Active User Active Member
    754
    113
    City:
    Danville
    State:
    California
    I would try making measurements using the 3-wire method. And using your measurement from the very outboard end (right hand end with the least wear) as your bench mark/reference measurement.
    I once bought a Bridgeport feed screw off of fleabay. Seller said it was NOS. When I got it, I noticed wear. Seller said I was mistaken. I proved him incorrect. Using the 3-wire method. Findings proved the center of the feed screw had several thousands wear. He took it back and also paid the return shipping…Dave
Share This Page
