- Feb 7, 2013
- 2,485
View media item 95767View media item 95766Needing a machine scraper, I decided to make one and see if it would cut the mustard. The business
end is a discarded SPG422 carbide cutter ground to what I think is a reasonable shape. It was silver
soldered to a piece of mild steel with a machined pocket. The long piece is a section of cold rolled steel
with a bit of spring to it. The handle part is from an old jig saw that I saved a few parts from. Both the
carbide cutter end and the handle end are removable so when the need arises, I can change tips or handles.
It's a first attempt so hopefully Richard King won't see these photos and laugh.
On a test it seems to scrape so hopefully I am on the right track. I'm open to any opinions from
the group.
the group.
