Watchmakers' Lathes
HMF
Site Founder
Administrator
Sep 22, 2010
7,223
Boley WW Type lathe from the 1920s
The much lighter "Geneva" pattern Boley with a flat-topped bar bed
A Boley watchmakers' lathe with triangular bid circa 1865
Not a design that caught on: the unusual Boley with a semi-circular base to the bed and a triangulated top.
An English-made BTM "Geneva" pattern watchmakers' lathe (note the bar-like bed with, in this case, a flat at the back) complete in its maker's fitted wooden box with a range of useful accessories. The item top left in the box is that most valuable of extras - a compound rest, used to hold a cutting tool manipulated under the control of screw-feed slides.
Boley Lathe No. 1b. A "WW" pattern lathe of a heavier pattern, admitting 230 mm between centres, and with feet at both end of the bed. On this model the compound slide was fitted as part of the standard equipment.
Nels-------From one of the "the Old Farts years ago" The Liberal Arts Garage ---
As I prepare to dry up and blow away , let me say that this unlikely group
project has defied any predictions of swirling internal confusion,thanks to
so many interested, interesting ,kind and patient men and women --- I hope
the new group can balance the unsought size and tantalizing opportunity
for greed and power with crossed fingers and love of new machinists starting
Into a thousand years of history .......BLJHB.
