- Jul 18, 2024
- 5
They can also do double-duty and hold a "ways cover" in place if you want to keep swarf off the vise screw.2) The screws keep swarf & dirt out of the holes, which are used to relocate the jaw plates to the outside of the body, increasing the size of the material you can hold. There's another set on the back (fixed) end of the vise. I'm assuming that the vise's jaw plates are secured with SHCS on the inside faces? These screws would be used to attached the relocated plates.
GsT
great idea! You can then mount the vise upside down and mill the saw cut so it looks nice...I suggest sawing off the coolant trough on the side facing the column! You won't regret that extra inch of room on a small mill!!!
However -- Uou chould check that the bottom is still flat after cutting the lip off... taking that lip off can release stress in the casting and allow it ti dish. Only happens a small part of the time, but is worth checking.
- your mill table is good enough to act as a reference if you don't have a surface plate. You will need to buy and learn how to use Prussian Blue to accomplish this.
Actually, if the Vevor vise is anything like my 3” that lip barely extends past the rear jaw plate when mounted on the back of the fixed jaw. Also, Y- travel will stop before the lip comes close to the column with the vise positioned as I suggested so the back of a part can be reached with an end mill.
I guess I was lucky, UPS didn't damage anything. I purchased the 4" version with the 360 Degree Swiveling Base and put the base in a drawer.I have the 3” and 4” and neither are a problem mounted in the center slot.
Then again my mill is partially home brew.
Op, how was the packaging and overall condition of your vise upon arrival?
Mine was bad enough (both damaged and manufacturing defects) I got two refunds from vevor, so I basically paid $22 for it.
For $22 I don’t mind the ding and the handle that was totally fubar from a manufacturing standpoint was repairable.
Packaging was scant to say the least.
