You can set the VFD to control a range of speed (actually frequency). Mine on the lathe is set to to vary between 30 and 60 Hertz. If you need more then you can change the belts and/or use the backgear.
Your question is not very clear, but in general you cannot use the lathe's (or mill's) existing controls since they will disconnect the motor from the VFD power source-and that is a huge no-no. You can possibly rewire the existing controls to operate the VFD.
Clear as mud?
Wow, I'm glad I saw this. I am getting ready to purchase a vfd for my heavy ten restoration and I wanted to use the original switch, so if I am understanding this right the original cuttler-hammer switch cannot be used with a vfd as it will disconnect power fed from the vfd and that's not good. Now I am unsure what I will do. Also if I am understanding this right, the only way to turn the lathe on and off is with the vfd? I kinda like the idea of being able to reach up and hit the kill switch for safety's sake. And then there's your last statement, "you can possibly rewire the controlls to operate the vfd" Now I'm intrigued, can the original switch be used to operate the vfd? That would be great if it could.
Greg, there are many threads on this. You simply rewire your machine's switch for low-voltage control so it will operate the VFD's F-N-R functions, and you can add a pot (potentiometer) to control speed as well.
Here is a thread to read: http://www.hobby-machinist.com/showthread.php/8009-A-VFD-write-up-for-a-Webb-Mill?p=66247#post66247 as an example even though he used a external switch.
Another one: http://www.hobby-machinist.com/showthread.php/7757-Wire-a-drum-switch-to-a-Teco-FM50
Anyway, I suggest you start your own thread and provide details and pictures of your motor and switch when your ready. We can also suggest the proper VFD with that info.
OK JT now we are making progress!
Your 220v "Mono" is what we call single or 1 phase power, and your 3x220 is what we call 3-phase.
Yes, you will wire the motor directly to the VFD, and then you will have to identify what contacts in you switch are open/close in the different positions with a ohm-meter or simple continuity tester. You will loose the dual speed function, but thats OK.
Does your machine have two motors? A and C in the diagram? Can you provide a key/description for the other letters please?
