    Dismiss Notice
VFD tuning for a Marathon motor
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by cut2cut, Apr 9, 2017.
  1. cut2cut
    cut2cut United States Active Member Active Member
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    I need some advice tuning my VFD to my inverter motor. I've been running it at 60HZ but wish to run the VFD at 120HZ for double the rpm.
    I have a Delta VFD-E ( 230V ) and a Marathon Inverter motor ( this is a different motor than what came with the mill ). Its working "ok" with the original default settings ( that were for the original motor ) at 60HZ but I just replaced the spindle bearings in my mill so they can now handle 7000 rpm ( with my 2-1 ratio pulley ). At 60HZ my motor turns at 1750 rpm and with the gear ratio I'm achieving 3500 rpm at the spindle. I want to run the motor at 120HZ so I can get 7000 rpm maximum *spindle rpm ( which is 3500 rpm on the motor )
    The VFD manual suggests I need to alter the mid point Frequency ( section 4-48 / parameter 01.01 ) . I'm not sure what to set it to. Also, when I attempted to set ( section 4-49 / parameter 01.05 ) to 2HZ the VFD error-ed and it auto set it back to the default 1.5HZ. The range is supposedly .1 HZ to 600HZ, so it must have some override if other settings aren't correct. I'm just not confident I can figure this puzzle out myself and hopeful someone experienced can lend a hand.
    enclosed are pictures of the Motor's specifications and also the VFD manual settable parameters for tuning the motor.
    And a link to the VFD manual is here :
    http://www.delta.com.tw/product/em/.../manual/Delta_IA-MDS_VFD-E_UM_EN_20140912.pdf
    Jake
  2. Maddogmech1
    Maddogmech1 United States Active User Active Member
    15
    8
    City:
    Owego
    State:
    New York
    -Return to Top-
    Maybe your drive is more complicated than the ones I use, but on mine I simply have to set the max output frequency to whatever I want, in your case 120hz.
  3. mksj
    mksj Active User H-M Supporter-Premium
    1,229
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Please see the attached basic parameter changes. The upper frequency is set by parameter 01.00. The Fbase is the base frequency of the motor or 60Hz, the mid-point I would leave at the factory default, this is not the half way point in the frequency range. Often two parameters will be tied together, so something like the minimum output 01.05 needs to match the motor minimum output 01.28. The motor type and load need to be entered into the MOTOR 1 parameters, the default poles is 4 for a 1750 RPM motor. The default PWM frequency 02.03 is 8kHz, if you have a lot of motor whine this can be set to 12kHz. There are a number of other parameters that may need adjustment depending on the control inputs and to do some tweaking.
  4. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    2,925
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    The motor plate shows it will go to 5400 rpm safely, so you could run it to 180 HZ to achieve that. Whether that is a good idea or not depends on other factors, including the spindle bearings. You did not mention what kind of mill it is. Sometimes there are other parts of the machine that will also limit the speed, like perhaps a variable speed drive. Make sure everything can handle the additional speed.
  5. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,722
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    That is a nice motor/drive combination.
    In addition to what @mkjs said above, I would set up the drive for Vector Control 00.10 = 1. much better torque control, and overrides some of the setup parameters.
  6. cut2cut
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    wow. Thank you @ mksj. I'll try those settings
    I have noticed the motor whine a bit, so I'll try adjust the PWM frequency too. I race RC cars, so I'm familiar with tweaking PWM but the speed controls for RC are far more "user friendly" / simple so outside of timing manipulation these VFD's are more complex beasts. btw, I falsely thought that Motor 1 settings might be just a series of presets. ( Motor 0, Motor 1, Motor 2 ).
    I received an over voltage fault while lowering the rpm, so I am told I need to increase the deceleration time parameter.
    @ Jim, does Vector control require feedback from the motors encoders ? Or is this just a setting. Its becoming more and more apparent that I should look in the manual a little deeper ( understatement of the year ! ). I actually have a durapulse VFD that I plan to use, which has a feedback encoder card.
    @Bob, I just got done installing Angular Contact Bearings in the spindle that should be good for 7k rpm. At this point, due to the gear ratio, I think if I used a higher frequency I'd lose too much torque and don't really need more rpm. If I need that sort of rpm, I'll probably get a 20k rpm high speed spindle to attach to the side of the head of my mill. In fact, that is something I thought to do someday.
    Jake
  7. JimDawson
    3,722
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    It depends on if it is a sensorless vector drive. I may have been making a bad assumption on that count, the Delta may or may not require an encoder. I didn't try to wade through the entire manual.
    The DuraPulse is a sensorless vector drive with an easy to use autotune feature. I have one on my mill and am very happy with it. Speed control and constant torque are great, especially at low RPMs.
  8. cut2cut
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    The only reason I haven't installed the Durapulse drive yet is because it physically is a bit larger requiring some "adjustment" to my electronics cabinet. hmmm, ok, I'll look into it now as you are making it look like I should just jump in and get that done sooner than later! :)
    Cheers,
    Jake
  9. JimDawson
    3,722
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    The one thing on the Durapulse is the braking resistor function, in order to turn it on, it is cryptically labeled '' overload protection'' in the manual. Required a call to tech support to figure that one out. ;)
    cut2cut likes this.
  10. cut2cut
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    I do have the braking resistor, so this is certainly good to be aware of ! Thank you
  11. Bob Korves
    2,925
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    My concern was not about the spindle bearings or the motor, which I assume your researched to be adequate for the speeds you intend. Beyond that, there may be other components of the drive system that are not up to the speed increase. For instance, a Bridgeport variable speed pulley system. Or something else... We don't know what mill you have...
  12. cut2cut
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Sorry Bob, after you asked I put my mill info in my signature and forgot to mention it. It's a Precision Mathews 1100+ pound "bench top" 3 axis metal CNC
    Mill. Model# : PM -940 CNC . I've removed the gearbox and replaced it with a pulley and belt at at 2:1 ratio.
    Jake
  13. Bob Korves
    2,925
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Sorry I missed your signature change. It sounds like you are only changing speeds with the VFD and now have no additional drive parts besides the two pulleys, the motor, and the spindle. If so, you should be fine, at least at the high speed end. At really low speeds you may not have enough torque and cooling for heavy work, or have you considered that?
  14. cut2cut
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Yes, at least initially I intend to adjust the VFD frequency when I need more torque, and down the road I intend to create a two pulley gear reduction setup for the ultra low rpm stuff. Right now I am basically just getting the mill functional and optimize it as I go. I do think about the possibility that I'll lack enough torque but have yet to mill enough to know if it's ok for my needs. It's been an "experience" just getting linuxcnc working and getting accustomed to the interface and new hardware. Baby steps :)
    Cheers,
    Jake
  15. cut2cut
    13
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    I just tried those settings. It worked a charm ! I can't say for sure, but I think torque may have increased, while also doubling the rpm ! Can't thank you enough.
    ( I put some drag on the spindle at 500 rpm and it didn't seem to slow much at all. I won't tell you how I did it, as my mother would not approve :) ).
    It may have to do with some of the settings getting bumped from 50 to 60hz that you pointed out.
    I also changed the PWM from 8k to 12k. This proved to reduce the motor noise. Getting closer to my goal of a silent mill ... lol :) I believe sometimes increasing the PWM can increase motor efficiency and possibly even torque ( although I previously equated lower PWM frequency with an increase in torque. A friend explained it has to do with matching the correct PWM with the inductance / windings.
    I think I'll use this Delta VFD for a while before switching to the other VFD. Its working and its always nice to be able to compare stuff.
    Cheers,
    Jake
Share This Page
