- Jan 28, 2011
- 3,585
I finished the install of a VFD and 2 hp 3 ph motor on my lathe. Used a Mitsubishi FR-D700 series VFD and a Techtop 2 hp 3 ph motor. The motor shop had a used motor that he would of given for free but it was just not right. For the motor mount I had to shift it towards the tailstock by 1 inch. The motor pulley needed to be rebored to the larger size and new keyway cut. Added a DPST switch for main power off at the drive box. I will have to add a speed pot knob and modify the existing control box so that I can close it properly, otherwise I am done.
For the wiring I used the existing wires from the apron switch for F/R, and reused the E-stop and Jog wires and repurposed the pump system wiring for the speed pot. I cut a new control panel, (it needs to be redone. A Monday job if I can get time on the machine. The milling file is already done) for the switches and pot.
Pierre
Pierre
