- Jul 28, 2017
- 2,555
I recently got this drill bit sharpener as a birthday present to myself. It seemed to have decent reviews (in contrast to some other Vevor products). It arrived a few days ago and I had an opportunity to try it yesterday and today, and now have some questions regarding its performance and adjustment.
In a video demo by Mr Pete, he indicated that the adjustment knob on the left side should be turned all the way clockwise, then backed off one complete turn past the drill max-diameter of 13mm before setting the dial to your drill size. So far he's the only one who has said this. It also is not what Vevor's owners manual says. Based on my experience so far, his suggestion is incorrect. So my first question is: what's correct, in other owner's experience? This operation sets the orientation of the drill's cutting lips w/regard to the ER20 collet holder so it's a critical step.
My second question is about the split point operation. As a preface, I have been using the 118 degree setting not 135 degrees. And in that vein, some online sources have indicated that the split point operation is best suited for 135 degrees, not 118 degrees. So my next question is: is that correct, in other owner's experience?
My third question also is about the split point function. With the factory settings, it didn't work. It produced a bit with a profile that looked like the drill had been ground too far back. So my final question is about the adjustment for achieving a properly functioning split tip. Have other owners found it necessary to adjust the grind depth? According to the Mr Pete video, one is advised to leave the adjustment alone. I've been using my stereomicroscope to examine the bit so I'm certain what it looks like after it's been ground. I've been sneaking up on a profile that looks like the one in the owner's manual and to do that has required some significant adjustments. Hence my question.
