- Jan 20, 2016
- 602
Ive been trying something new recently by CNCing my X2 mill and it has lead me to a lot of things I don't understand or need to improve.
Motor Questions:
How can I tell if the brushes need to be replaced? I know its lost steam recently. Around February last year I drilled a 3/4" hole in 303 stainless up from a 1/2" hole. It was slow going but it didn't stall. Just recently, I tried to do the same thing in 6061 and it would stall out almost immediately.
My motor is advertised as 4/5 HP, but everything I can find says it is running at 350W. 4/5 HP would be 595W, and even at 110V and 4.5A, thats only 495W. How can I figure out how much power it is actually drawing?
I have read about people replacing their controllers to improve speed and torque. The boards I have found are about $75 shipped. I have found a lot of treadmills with 2HP+ motors for around there. Any reason I should do one of these over the other?
Spindle/Tool Holder Questions:
I am going to be using TTS holders with a .75" collet. What amount of spindle runout is expected/reasonable? I am all about chasing small numbers, but I need to know when I am wasting my time.
Since the holders will be tightening against the spindle face, should I face that? Anything wrong with tightening a lathe tool into the vise and just cutting it with that?
Several miscellaneous questions:
Is it safe to use loctite on gib screws? I find that even with the nuts locked down, nothing stays tight for more than a day or two worth of machining.
Any tips on taking light cuts in 4140 on the lathe while still getting a good surface finish? When turning at about 600 RPM near .750" diameter with a 3/8" insert tool, I get a perfect finish with .0015" cut depth, but anything less than that and it comes out very rough. I haven't been able to get HSS to cut it well.
Any help you guys can offer is greatly appreciated.
Motor Questions:
