4
Using Large Flat Belt Pulleys With V-belts
3
Like what you see?
10
markba633csi
Active Member
Active Member
Apr 30, 2015
1,318
Likes
526
#1
I see this is commonly done on machinery which (I think) was originally run from a master line-shaft system. I'm enclosing a picture of Wildo's 9A restoration as an example; my Diamond mill has a similar setup. How does the belt stay on if the large pulley isn't crowned? Would a serpentine or leather flat belt be a better choice, and the motor pulley changed over to a flat one (with a crown)?
Wreck™Wreck
H-M Supporter-Premium Member
Sep 29, 2014
1,918
Likes
1,463
#2
The belt is positioned by the driving V-belt sheave, flat belts do not require crowned sheaves, alignment is important however.
Klaatu barada nikto
12bolts
Global Moderator
Staff member
Active Member
Apr 23, 2011
1,929
Likes
368
#3
My shaper has a large flat driven pulley. From what I have seen when the 2 pulleys are in close proximity tracking is not a problem as the smaller V pulley keeps it positioned
cheers Phil
markba633csi
Active Member
Active Member
Apr 30, 2015
1,318
Likes
526
#4
I just wondered cause the v-belt is not really designed to run on its inside surface, but it seems to work anyhow. A simple solution and cheap. The best kind.
Mark
M
Mister Ed
Guest
#5
This was standard on Logan lathes, for the belt from the motor to the jackshaft. It makes changing pulleys (speeds) very easy with just a little release of tension. I have never seen a tracking or tension issue. Jackshaft to spindle is/was flat belt.
12bolts
Global Moderator
Staff member
Active Member
Apr 23, 2011
1,929
Likes
368
#6
I think you will find it mostly occurs when the flat pulley is of a quite large diameter. Consequently the massive surface area of the belt on the large pulley really negates the issue of the v belt running on its inside face
Cheers Phil
benmychree
John York
Jun 7, 2013
998
Likes
565
#7
Klaatu barada nikto
I beg to differ, flat belts are always run on crowned pulleys. Perhaps you meant to say that in a vee/flat drive, the vee belt does not need to be running on a crowned pulley.
benmychree
John York
Jun 7, 2013
998
Likes
565
#8
I ran a line shaft in my shop many years ago and used a vee/flat drive with a two grooved sheave on the motor about 4" diameter using belts approximately 7/8" wide running on a 30" diameter pulley on the line shaft that was crowned; the belts nestled up against each other , and it worked fine and slippage was not a problem with a 3HP motor driving.
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,297
Likes
3,495
#9
my SB11" lathe has a similar drive , the motor pulley has a v pulley- the rest of the drive is done with flat pulleys.
6
5 7
