Using a lathe to wind springs?
HMF
Site Founder
Administrator
Sep 22, 2010
7,223
Has anyone used a lathe to wind springs such as an extension spring with closed coils out of .037 music wire?
How did you set it up?
Thanks!
Nelson
1 Set the screwcuting to the pitch of the spring
2 guide the wire through a tube in the tool holder
3 put wire drum on a horizontal spindle to your rear
4 tension the wire using thick leather gloves
5 anchor the first end by drilling a cross hole through the winding spindle.
I have done this lots of times, by having the wire drum a long way away, you can stop the lathe when tings go wrong, use a low speed.
Drawfiler
drawfiler is right on. I did hundreds of them years ago in trade school but the only difference was i used a spring winder in the tool post to keep the wire tight. I finally tracked one down a few years ago and will get a pic of it...Bob
