- Dec 31, 2013
- 327
Had the batteries in the Laser tach for another job, so I thought I would check the results on my SB 10 UMD with a flat belt.
The first number is what I got, the number in parenthesis is from the chart in How To Run a Lathe.
Comments:
In High I'm running slower than spec, but in low the lathe is running faster. With these results using anything in high speed except position 1 isn't much different than staying in low. Also, I don't like running this old lathe in the fastest setting so it looks like I'll won't be changing the V belt position very often.
Right now I'm using a single phase 120V motor but I still have the original 3-phase motor. I can see why people like to use a VFD with these lathes, because not only do you get the soft start but you can also nudge the motor speed up and down to get some more speed settings.
1 | 2 | 3 | |
High | 1380 (1435) | 822 (844) | 488 (502) |
Low | 798 (706) | 469 (415) | 277 (244) |
Back Gears (in Low) | 153 (137) | 90 (80) | 54 (48) |
Comments:
