need help again!!! finaily get back in shop after the snow we had tis winter. got to amite my powerchair did pretty good in some of the snow. but anyway still got my south bend lath that you all help me get power to ,still getting it set up but getting closer ..thanks to all the great info would have burnt up a few motors before I got working by myself.. but to my new problem. I have a wholesale tools mill/drill that I installed a power table feed also an inport it's a ALSGS AL-310S. it's worked fine for few years but I don't use a lot . anyway started to mill a part and put it gear and poof blew a breaker reset and did again so I opened up and found a wire that the shrink wrap wasn't covering wire completely. repaired and put back together.tried to use again it would hardly move and sounded bad (grouling) so pulled brushes one was junk ..found a set I made work. seems like it works fine until I plug in the mill then the power feed hardly works again if I un plug the mill from the wall the power feed seems to work fine again, all speeds work also the fast speed button works great also.then I just plug the mill back in the wall plug ,and feed starts working like crap ...also mill is not switched on, just pluged in wall socket. .. now I just noticed that even when the feed seem's like it's working fine ,it's not it's really working backwards.which I didn't notice till lastnite reason I think this is because when I put in gear and press the safety stop switch it works backwards.. does any of this make sence to any one... sorry about my spelling can't find my spelling check...lol
