    Dismiss Notice
Unknown Collet type
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by knutselaar0, Aug 4, 2017.
  1. knutselaar0
    knutselaar0 Belgium Iron Registered Member
    14
    3
    City:
    9850 Hansbeke
    State:
    Outside US / Canada
    -Return to Top-
    Does anyone know this kind of collet?
    It has 10 ° angle,( 20 ° taper)
    The ER collets are 8° ( 16° taper)
  2. Karl_T
    Karl_T United States Active User Active Member
    194
    43
    City:
    Dassel
    State:
    Minnesota
    -Return to Top-
    Look up TG type collets, TG100 most common, also TG75 and TG150
    Ulma Doctor likes this.
  3. knutselaar0
    14
    3
    City:
    9850 Hansbeke
    State:
    Outside US / Canada
    -Return to Top-
    Taper angle of TG collets is 4.175° , i a need 10° angle
  4. kd4gij
    kd4gij United States Active User Active Member
    1,129
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    What is the diameter od and id.
  5. knutselaar0
    14
    3
    City:
    9850 Hansbeke
    State:
    Outside US / Canada
    -Return to Top-
    I just want to know if these collets exist
    Because i have a spindle with a 20° taper and i need collets for the spindle
  6. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,220
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Sounds like your spindle is set up for using a Warner Swasey turret lathe style collet. See the next thread for a a couple of examples. I think you need to look at your spindle bore a little closer behind the angle. We NEED some dimensions of your spindle so a collet can be found. Again, the samples in the other thread is the configuration you need to look for in your spindle. The thru bore of your spindle will probably be the same size as the tail end of the collet you are looking for.
    Ken
  7. knutselaar0
    14
    3
    City:
    9850 Hansbeke
    State:
    Outside US / Canada
    -Return to Top-
    I think the spindle is from a internal grinder, no spindle bore
    The collets are not for myself, but for a friend
    The taper is 20° (10° angle), biggest diameter is about 24 mm
  8. 4gsr
    2,220
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Now we are getting more information. That helps. Thank you kindly.
  9. kd4gij
    1,129
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    look at 4c and 5c collets. They have 10 deg taper
    4gsr likes this.
  10. knutselaar0
    14
    3
    City:
    9850 Hansbeke
    State:
    Outside US / Canada
    -Return to Top-
    It's an old round belt driven internal grinding spindle
    Made by GMN R50680
    I've modified the inner taper to a taper for ER25 collets
    4gsr likes this.
Share This Page
