A few weeks ago I got an Emco Unimat DB SL and disassembled it for some servicing, after assembly however something isn't right at all anymore.
At first I thought the spindle got bent somehow but I visited a shop today and they helpfully measured it and it turned out that it's off by 4/100th mm (withing manufacturing tolerances according to the manual), so that can't be it really.
Next I took a straight rod and put it in the chuck (and repeated that later with a collet) and a drill. They both seem to be true too.
However, as soon as I screw the chuck on to the spindle it's off again by quite a bit. A 150x10mm rod would completely miss the tailstock. In short the lathe is completely unusable as it is now, but was usable when I got it.
I'm thinking something might be funky with the threads, but how would I find out/what should I do?
I hope I've been clear enough that you can kinda figure out what I mean., Otherwise please do ask!
Thanks a lot!
Thanks a lot!
