- Jan 21, 2013
- 36
I just finished building this engine. It was designed by David Kerzel http://www.john-tom.com/html/SteamPlans3.html. I made mine 2x scale from David's plans. I used stainless steel for the cylinders, brass for the pistons and connecting rods, drill rod for crankshaft, aluminum for the crankcase, flywheel, cylinder heads, etc. Brass and copper tubing for the intake. I also added a "porthole" so that one can view the action inside when the engine is running.
