  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Turret Riser for a PM935?
3
Like what you see?
10
Alan H
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Oct 10, 2016
642
Likes
665
#1
There is a thread here on raising the turret of a Bridgeport mill and how to get it on the machine. These risers for BPs are evidently readily available. Watching the thread provided a glimpse into the relative ease of installing one.
I then began to ponder the addition of a riser to my PM935TV. I am imagining a 6" riser. I have wanted to raise the mill with a stand about 6" to 8" anyway and a riser would be a far better solution for me. Would increase the vertical capacity of the mill and generally raise the table for for most work.
Has anyone found a source for a Riser for the 935? Any owners out there put one on a PM935?
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,993
Likes
1,713
#2
The PM935 is said to be the same mill as the Modern 935VS. I remembering drooling over that Modern mill & when the PM935 came out I was excited. I remember someone installing a riser on their Modern mill.
Alan H
Oct 10, 2016
642
Likes
665
#4
Thanks Will, I searched without success. I too looked on Modern's website. I will send them a note and ask. I have also sent F350 a PM.
A few months back Matt indicated he didn't offer a riser on this thread and indicated why. Perhaps Matt will see this and add a little more insight.
f350ca
Active Member
Jul 11, 2013
1,182
Likes
1,844
#5
I bought my riser from Modern Tool, where I'd bought the mill while living in Alberta. They are incredible to deal with. I called them up, gave them the serial number and they knew what I needed. Said if I wasn't in a rush they could put one on the next container from Taiwan at no charge. It got to Calgary, they called and said if I wasn't in a rush they had a truck going to their store in Toronto at no charge. Arrived in Toronto, again if your not in a rush the guy was driving to Ottawa in a week or so. Met him at his hotel. Free shipping from Taiwan to Ottawa Ontario.
Greg
Alan H
Oct 10, 2016
642
Likes
665
#6
Thanks for the insights Greg. Now to figure out the requirements for my PM935. There are indications that the machines are made in the same factory so I'm betting they are available somehow.
You have any photos of the details of yours and it going on? How is the spider configured on your mill?
Thanks again, very helpful.
f350ca
Active Member
Jul 11, 2013
1,182
Likes
1,844
#7
Sorry Alan I don't remember much about the spider, just looked it was 5 years ago I installed it. I think there were lugs in the column casting that held it up till you got the bolts in.
Have a photo of the rig I had to use to balance it while I elevated it with the overhead crane.
The riser was dirty from laying on the shop floor for a few years before I installed it. This is a 10 inch one. I like the height, but have to use an ER collet chuck to reach work clamped flat to the table. I also use the swivel now on the vice to gain some height, not a common problem. As I said I like it in there, the table is at a much more comfortable level to work.
Greg
Alan H
Oct 10, 2016
642
Likes
665
#8
Thanks Greg for the photo.
I didn't realize you added that much height. I have been thinking about 6" for my PM935 and have been wondering if that was about right.
The body of your machine looks larger that the PM935. I think the OD of a riser for the PM935 would be about 11.5" and yours appears to be a larger diameter than that. Is yours about 15" OD?
f350ca
Active Member
Jul 11, 2013
1,182
Likes
1,844
#9
I'll measure it today Alan.
I've needed the full of the riser for a few operations. This is the body of a 10 inch inlet valve on a big rotary compressor. The pivots were worn, causing the gate to stick at times.
On a side note, always wondered how they controlled the output of a rotary compressor. They don't, they shut off the inlet when air isn't required, that way the valve only has to handle atmospheric pressure (14.7 psi)
Greg
Alan H
Oct 10, 2016
642
Likes
665
#10
Thanks Greg, that rough measurement would be really helpful. (BTW, the famous red x showed up for the photo of the valve - Tapatalk?)
I really do expect that your measurement will confirm your mill has a larger stanchion/body than the PM935.
Ref. output of the rotary compressor, interesting isn't it? From a thermodynamic viewpoint it keeps the compressor from doing "work" and it is far more efficient that way.
f350ca
Active Member
Jul 11, 2013
1,182
Likes
1,844
#11
No problem Alan.
Don't know why I get the dreaded red-x, Im posting from an Apple desk top.
Greg
Alan H
Oct 10, 2016
642
Likes
665
#13
Greg, this confirms that your machine and the PM935 are different. Your machine uses a standard size diameter riser that can be acquired from numerous vendors. Of course it does not fit the PM935. Thanks Greg for all your help nailing this down.
Alan H
Oct 10, 2016
642
Likes
665
#14
I have been in touch with Matt at QMT and he was kind enough to reach out to the factory to see if they make a riser. As usual, Matt was quite responsive and I heard from him today and unfortunately the factory does not make one. Matt is also not aware of anyone who is making one so he cannot recommend any alternatives at this point.
Alternatively one might considering making one form DOM tubing. The material does appear to be available in a diameter and a thickness that should work well. I'll give that some thought.
f350ca
Active Member
Jul 11, 2013
1,182
Likes
1,844
#15
Glad the measurement helped. I had originally thought about making one but the price on this one was too good. The one concern I had with making a steel one was whether the steel would ring.
Greg
[6]
5 [7]
