- Oct 14, 2014
- 1,970
Daryl,
I've used a hardinge turret a fair bit before switching to CNC lathe.
Set up is a fairly long process. Generally not worth it unless you are making at least 20 each of a part. They fell out of favor cause a CNC is worth it if you are making two parts.
First plan your order of operations. Put tool 1 in the first position, tool 2 in 2, ya da ya da. Then go through and set your stops for each tool. One thing I found, just set the stops only fairly close by eye the first time. You'll then see that you should re do one of the tools right away before trying to get in spec. Also, it really helps to set up the tools so you don't need to move X very much.
I could stop by if you have a specific detail question.
Karl
PS, A thought for you. I had considered building a custom DRO with a different offset for each turret position. Then you could leave the turret set up with several common tools and quickly make parts.
Karl
