    Dismiss Notice
Trying To Build Dividing Head
Discussion in 'MACHINE ACCESSORIES (Tables, Vises, Indexers)' started by Lordbeezer, Jan 8, 2017.
  1. Lordbeezer
    Lordbeezer United States Active Member Active Member
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    hello..trying to make simple dividing head.want to make it 40:1 ratio.40 tooth to a 10 tooth gear would be 4:1 if I'm correct.if not please advise..to get 40:1 I would use 400:10...looks right but can't be..that's a lot of teeth..made a worm wheel(gear) worm gear was 1/2 x 20 bolt thread.took 193 cranks of handle in front of hole plates.want to gear it like normal so I'll know how,after looking it up to move pin in plates.been goggling for hours trying not to ask dumb a@& questions. Thanks for your time
  2. Tony Wells
    Tony Wells United States Former Vice President Staff Member Administrator
    19,389
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    You should only turn the input 40 turns to achieve 1 turn of the output. I will refer you to a website belonging to one of our members, Mr. Harold Hall. He has many projects on his website.
    http://www.homews.co.uk/page425.html
  3. hman
    hman Active User H-M Supporter-Premium
    982
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Lordbeezer -
    Your post was a bit unclear, but I think you were asking about how best to get the 40:1 ratio, and if you could use a ½-13 threaded rod to get there. I'll answer with that assumption in mind. If I'm off, please let me know.
    Worm drives are generally the way to go to get high ratios with just one stage of reduction.
    To get 40:1, you'll want a 40 tooth worm gear to work with the worm. Think of it this way ... One turn of the worm will advance the thread one "tooth" - one thread pitch - same distance as a nut would move on such a screw. Meshing a 40 tooth gear against it means you need 40 turns of the worm to get one turn of the gear.
    If you want to use ½-20 threaded rod for the worm, the "pitch diameter" of a 40 tooth mating gear would be
    40 teeth x 1/20" per tooth ÷ Pi = 2"/Pi ≈ 0.637" That's not a very large or robust gear, but it can be done. Of course, you'll have to calculate the OD of the gear blank from standard tables, etc etc. Then you'd have to find or make a suitable cutter for the teeth.
    And, of course, your accuracy would be limited by the accuracy of the original threads on the rod.
    Hope this helps.
    brino likes this.
  4. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    Sorry I wasn't very clear..my first attempt was with 1/2 x 20 driving a gear I cut with a 1/2 x 20 tap..put together it took 193 turns of handle for one 360 circle..been googling to see what gears to use to make it 40:1 so I can use dividing plates the Normal way.. Have several gears...one set would make it 4:1...going back to mr,Halls website to look some more.can't find anywhere it says use this combo of gears to make 40:1...maybe I'm missing a simple answer but I sure don't see it..I guess I'm asking what tooth gear driven by what tooth gear to get 40:1...thanks very much for you time..Phil
  5. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    Does it matter what final drive gear ratio it has as long as I keep up with holes in dividing plates.sorry for questions that are probably simple to y'all but wearing me out.Thanks
  6. hman
    982
    113
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    OK, I think I understand your questions a bit better now.
    As for an overall gear ratio of 40:1 with standard spur gears ... yes, you do have the right idea. A 400 tooth and a 10 tooth do indeed produce a 40:1 ratio. Other combinations will do so. Just look for the "lowest common denominator." It's also possible to go in multiple stages - a 10 tooth driving a 50 tooth (5:1), with the 50 tooth on the same shaft as another 10 tooth, which in turn drives an 80 tooth (8:1). 5*8=40.
    The "gotcha" in such an arrangement is backlash - each reduction stage makes its own contribution. Adding more gears can also affect overall accuracy, as each gear contributes.
    As for your original test, which produced a 193:1 ratio, you might consider reducing the diameter of the worm gear by a bit more than half, and work toward a 90:1 ratio, This is also a "standard ratio" for dividing heads (4º rotation per turn of control handle). You might have to try several times to get it exact, but it should be do-able. Then find a set of dividing plates meant for a 90:1. I myself bought a Grizzly 90:1 rotab (H2677) a year or two before I found a set of dividing plates to fit it. The part number for Grizzly's plates is G9295, $80 plus whatever shipping they charge.
    The dividing plate set includes setup instructions for dividing a circle into a goodly number of even patterns - all spacings from 1/2 to 1/66 of a circle, most from 1/68 thru 1/120, about half of all spacings from 1/120 to 1/180, and some others. I'm sure that commercially available dividing plate sets for 40:1 rotabs will have similar instructions.
    In answer to your last question - YES, it can matter a lot. Calculating the setups from an arbitrary ratio (such as your 193:1) and an arbitrary set of dividing plates is possible, but messy. And unless the ratio is easily divided into 360º, very few exact solutions can be found. PM me if you want details of such calculations.
    royesses and brino like this.
  7. rdean
    rdean United States Active User H-M Supporter-Premium
    642
    93
    City:
    Weirsdale
    State:
    Florida
    -Return to Top-
  8. brino
    brino Active User H-M Supporter-Premium
    2,225
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    @Lordbeezer
    Here's the direct link to the worm gear discussion mentioned above (and linked to from the rotary table thread above):
    http://www.hobby-machinist.com/threads/make-a-worm-gear.36588/
    It is a very detailed discussion of the problems with cutting a worm wheel with a tap. See especially post #29 in that discussion:
    http://www.hobby-machinist.com/threads/make-a-worm-gear.36588/#post-313536
    getting a repeatable tooth count is hit and miss.
    However, you may be able to find a small worm-gear mechanism for cheap. Check around scarp yards for junk winches, garden tillers, lawn mowers, etc. I've even found one in an old washing machine. Try to find one with a 40:1 or 90:1 standard ration, then you can get pre-made dividing plates.
    Good Luck, and please let us know how you progress.
    -brino
    royesses likes this.
  9. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    Ray..yes sir I have..very nice work..that's what got me to try and make a worm wheel.used 1/2 x 20 thinking finer be better..not the case..I already have 40:1 plates.trying to match my ratio so I can use them..going through my gears to see what I can come up with..your work makes mine look like cave Man stuff..thanks Brino..thanks for info..rdeans article got me to try and make a worm wheel..I have a box of lathe gears.two winches to go through and two leadscrews so maybe I can end up with 40:1...using a old headstock off atlas lathe for my base.thanks for your time..Phil
    brino likes this.
  10. Jim2
    Jim2 United States Active User Active Member
    18
    8
    City:
    Madison
    State:
    Wisconsin
    -Return to Top-
    Another option is to purchase the gears. . . . I bought mine off Amazon a couple years back when I built my dividing head. The ones that I used are a) worm, and b) worm-wheel. Yeah, I know--kinda pricey! It's just money, right?
    Jim
    brino likes this.
  11. chips&more
    chips&more United States Active User Active Member
    1,222
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Please don’t get me wrong. There is lots of pride and fun in making whatever yourself in the home shop! But, there is also lots of fun in hunting down a second hand factory made one as well!
  12. rdean
    642
    93
    City:
    Weirsdale
    State:
    Florida
    -Return to Top-
    Using a 1/2 X 20 tap to make a 40 to 1 ratio worm gear will result in a very small final gear less than 0.750.
    Lets try a 1/2 X 13 tap.
    1" divided by 13 = 0.077 per tooth
    Number of teeth + 2 =42
    42 times .077 = 3.231
    3.231 is the circumference of your gear blank.
    Divide 3.231 by 3.14 to get the diameter of 1.029"
    This is still really small to work with so lets try an 11 tooth per inch example.
    1 divided 11 =0.090 per tooth
    42 teeth times 0.090 = 3.818
    3.818 divided by 3.14 =1.215 " in diameter. Still fairly small.
    In my case I wanted 90 teeth on the worm wheel which ended up at 2.254 in diameter.
    If you want to stay with the 40 to 1 then I would look for a courser thread on the worm shaft to start with.
    NOTE
    In order to make exactly the number of teeth you want when cutting the blank you must gnash the blank at each place you want a tooth.
    The cuts need not be deep (0.025 - 0.050) just a place for the tap to align with. Turn the tap by hand the first couple of rotations paying close attention that each cut slit is centered on the tap tooth. I made several worm wheels with different ODs trying to get the correct number of teeth without cutting the slits and never was able to one right.
    Now for the next question how do you cut 40 gnashes around a blank accurately with out a rotary table or an indexer?
    I don't know.
    Have fun
    Ray
    brino, coffmajt and francist like this.
  13. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    Thank ya'll very much for your help..have a 50t and 80t gears.gonna make 2 10t..put then together per hmans post for my 40:1...hope it goes as simple as it sounds..if I wanted to make a worm wheel with 100t cut with a 5/8 X11 tap how big should my blank be.ended up with 105 with blank at 2.890..Thanks
  14. DaveInMi
    DaveInMi United States Active Member Active Member
    78
    18
    City:
    Cheboygan
    State:
    Michigan
    -Return to Top-
    I made my dividing head from the Gingery book. I bought some acme ready thread and used it to cut the worm gear. I cut some gashes in the ready thread and mounted it in the lathe between centers. I mounted the gear blank on a post on the compound slide. The ready thread cut the worm teeth. It worked like a hobbing process without power to the gear blank.
    royesses and rdean like this.
  15. willthedancer
    willthedancer United States Active Member Active Member
    167
    43
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    I'll weigh in on this,
    You can make a worm wheel for any thread pitch by making sure you have the right diameter on the wheel you want to cut. It just has to work out to 40 teeth at the pitch line.
    That said, if you use a standard fastener thread, it will have a 30degree pressure angle. That tends to force the worm and wheel apart. An acme thread has a 14 and a half degree pressure angle, and much more force is transmitted to turning the wheel rather than forcing it apart. you want polished threads too. A rough worm will eat your bronze gear.
  16. willthedancer
    167
    43
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    I bought my worm and wheel from Martin BTW.
    rdean likes this.
  17. mickri
    mickri United States Active Member Active Member
    19
    8
    City:
    Squaw Valley
    State:
    California
    -Return to Top-
    With google sketchup it is very easy to divide a circle into any number of equal divisions. Attached is a drawing that took me less than 5 minutes to create where I divided the circle into 40 equal divisions.
  18. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    Thanks for the information.took a 50t driven by 10t driving a 8t turning a 64 t to get my 40:1..finished indexer today.going to use it for awhile then take apart and paint..thanks for everybody's help..Phil..I'll post pictures of my Fred flint stone special after paint
    brino, royesses and rdean like this.
  19. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    Quick note.was buying a few items from a retired machinist I showed him picture of indexer.he said he had a small one with foot from 20-30 years ago.never used it..bought it real quick..Dayton electric .made in Taiwan.looks real nice. Thanks
  20. Larry Hoy
    Larry Hoy United States Iron Registered Member
    6
    3
    City:
    Oak Grove
    State:
    Missouri
    -Return to Top-
    I have just finished a dividing head shown in the June/July 2010 issue of the Machinist's Workshop it is easy to build and uses any gear for indexing. A worn indexing module is shown in the Oct/Nov 2010 issue it uses 3 gears and 1 index plate with 3 hole circles it will index most of the divisions that would be needed.
    4gsr and brino like this.
  21. markba633csi
    markba633csi United States Active Member Active Member
    373
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Just saw some 40:1 steel worm gear sets on Aliexpress for about 18 dollars
    Looked perfect for a stepper motor divider I had in mind
    Mark
  22. Keith Foor
    Keith Foor Active Member Active Member
    198
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    Are you wanting to build one so you can say you did?? Or are you wanting one and can't find one?
    I have one that I would let go for a ben franklin or trade for tooling
    Let me know
  23. Lordbeezer
    60
    28
    City:
    Wake forest
    State:
    North Carolina
    -Return to Top-
    No..lack of money..it was fun though.its not near as nice looking as the ones made by members here..but it does work..what brand is yours?what tooling you interested in.? Thanks Phil
  24. Keith Foor
    198
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    It's a Kempsmith dividing head. Large and heavy. It's not as heavy as my Cincinnati but it's close.
    http://s1306.photobucket.com/user/Keith_Foor/media/K dividing Head/20160612_125813_zpsbldayith.jpg.html?o=1
    Sorry for all the adds on photobucket.... seems it's turned into photo bucket o crap adds.
    Just scroll through the pics. It's the K model dividing head. It is rather old, but it's very tight and seems to work well.
    As far as what I am looking for.
    8 and 10 inch grinding wheels for surface grinder with 1.25 arbor hole
    mag chuck for a 6X18 grinder
    sine plate or compound sine plate
    insert tooling for lathe or mill with common inserts
    If you have other machining related stuff you would like to offer up feel free, there is always stuff that I am looking for that I don't realize I am looking for until I see it.
    [​IMG]
Share This Page
