    Dismiss Notice
trouble installing 5C collet chuck
Discussion in 'PRECISION-MATTHEWS' started by oldhank60, Jul 4, 2017.
  1. oldhank60
    oldhank60 United States Active Member Active Member
    11
    8
    City:
    Bournville
    State:
    Ohio
    -Return to Top-
    I thought it would be simple but noo it had to become complicated, I got the 5C chuck that quality sells, I found I really don't like it because I need to buy another chuck key one that does not have the spring on it,
    yesterday was first time I tried to install the 5C collet chuck, no biggie right! it comes with the pins un a bag and you have to screw them in and then the lock bolts, no major thing except I did that and 1 pin would not tighten up. the pins on chuck D1-4 type all have location ring ( guess ) to make where or how long each should be. chuck did not have any direction on this, I have no experience at this.
    Could some one please tell me how the 3 pins on a D1-4 camlock chuck are supposed to be installed correctly, and what to do if they don't lock up,
    thank you Hank Kettler
  2. mikey
    mikey Active User H-M Supporter-Premium
    2,574
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    The line on the pins are supposed to be at the level of the back of the chuck, then line up the scallop for the socket head cap screw and snug down that screw. This should allow the chuck to install on the spindle so that the indexing mark on the three spindle locking studs falls between 3 and 6 o'clock when the stud is locked.
    The D1 stud in back of the chuck may feel slightly loose; they all seem to be that way.
    darkzero and Bob Korves like this.
  3. Chipper5783
    Chipper5783 Active User H-M Supporter-Premium
    364
    63
    City:
    Red Deer
    State:
    Alberta
    -Return to Top-
    That ring is just a starting point. All D1-4 mounts are not quite the same. Sometimes the pin does not have an indicating ring. I don't think any of my chuck mount pins have the ring (I think I have 8 devices with D1-4 mounts?). You probably just need to turn the pin in or out a turn. I have two lathes that are both D1-4, but if I want to swap chucks between them, I have to adjust the pins. Now that my chucks and face plates are set up for the respective machines, I just switch machines.
    The point being, adjusting the pins to fit your spindle is a normal task.
  4. mikey
    2,574
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    This might help ...
    Chipper5783 likes this.
  5. pstemari
    pstemari H-M Supporter - Premium Content H-M Supporter-Premium
    250
    63
    City:
    Renton
    State:
    Washington
    -Return to Top-
    Fwiw, you can yank the spring off the key easily enough. When changing collets I yank the spring off, but I keep it on the rest of the time.
    Sent from my Pixel XL using Tapatalk
  6. DaveD
    DaveD United States Active User Active Member
    24
    18
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    One big word of caution...
    DO NOT try to hurry the adjustment process by skipping putting in the locking screws. Put them in EVERY TIME. If one of those studs would happen to turn the wrong way while you are doing the trial fittings you may never get the chuck off again.
    darkzero likes this.
  7. Alan H
    Alan H United States H-M Supporter - Premium Content H-M Supporter-Premium
    486
    63
    City:
    Spanish Fort
    State:
    Alabama
    -Return to Top-
    Hank, It would help if we knew which chuck you bought. What is the brand of it?
    I could post some photos of one if it is the same.
    Did you get the collet indexing pin installed properly? That can be a bit confusing and a bit of a challenge in the absence of instructions.
  8. oldhank60
    11
    8
    City:
    Bournville
    State:
    Ohio
    -Return to Top-
    I don't know if pin is correct, it came with no direction, I will look to see what brand when I go out to shop again
  9. oldhank60
    11
    8
    City:
    Bournville
    State:
    Ohio
    -Return to Top-
    thanks for advise about locking screws, I already thought it would be a bad thing to install and a pin turn, so I always install with what I have tried.
    the ring around the pin does not seem to be correct I put all at same height and one does not lock up, all my other chucks work just fine, or they did I have not tried anything else since I started with 5C collet
    the locking bolts will only install if pin is in correct indexing position, so that's not the problem,
    thought I better add this, not only does it not lock up the cam loc on spindle head free spins on that 1 pin, I have removed chuck and put different pin in the cam loc that was not working and it works fine, that tells me its the chuck that has the problem, I have not made it out to shop again , it is a made in china chuck
  10. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,538
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    A pic might better help...
    The ring is only a base starting point. Like the others mentioned, lock up should be between 3:00 & 6:00. Like in the pic below, the line on the cam lock should fall in between the 2 arrows. If the line does not quite get to 3:00, unscrew that pin one revolution & try again. If the line goes past 6:00, screw in the pin one revolution & try again.
  11. oldhank60
    11
    8
    City:
    Bournville
    State:
    Ohio
    -Return to Top-
    I want to thank everyone for the replies, I'm sure with the help I am receiving here I will be able to get it working. will keep this up dated till problem is solved
    thank you
    Hank Kettler
  12. bfd
    bfd United States H-M Supporter - Premium Content H-M Supporter-Premium
    177
    43
    City:
    nipomo
    State:
    California
    -Return to Top-
    If the notch on the adjusting screw is between the two arrows then it is correct. like the picture above it is correct. you may try to get it further, but it will stay locked in its current position. bill
Share This Page
