  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
Tramming your Vertical Milling Head
Discussion in 'METAL FINISHING, CUTTING & WORKING' started by itsme_Bernie, Aug 11, 2013.
  1. itsme_Bernie
    itsme_Bernie United States Active User Active Member
    69
    48
    City:
    NNJ
    State:
    New Jersey
    Hello Ladies and Gentlemen (and all other members hyah hah)
    I have a Model 70 Rusnok Vertical Milling head mounted on the 2 inch overarm of a Hardinge TM Mill.
    What method do you use to tram your head? I know there are lots of methods, I use a few, but it can only help to know what other ways are out there.
    I have an EZ Tram "Nano Tram" stand that goes over the vice, and use an indicator and swing it in a collet. This method is not always an option because it can interfere with work in the vice, since it has to span over the vice. This defeats the purpose.
    I occasionally use a square from the mill table to the side of the Rusnok, which has a flat machined on the side for this purpose. But again, not always possible.
    I also have one of those Coaxial indicators, which is great, but uses a lot of "Z" room, and I have had situations with a rotary table and chuck where it wouldn't fit!
    What methods do you guys use? What tips and tricks have you found helpful to do this more accurately, quickly, simply? Or what is just the best and most accurate way when you have time and space?
    Thanks for your opinions!
    Bernie
  2. terrywerm
    terrywerm New Member Liaison Staff Member H-M Supporter-Premium
    445
    83
    Central Minnesota
    City:
    Jordan
    State:
    Minnesota
    I usually tram the head to the table, and just use a DTI and mount clamped in a collet.
  3. Rick Leslie
    Rick Leslie United States Active User Active Member
    64
    48
    City:
    Macon
    State:
    Georgia
    Same here, except I have an old bearing race that's about 8" in diameter. I lay it on the mill table an tram the race surface for uninterrupted DTI travel. The race is ground true so there are no variations in the surface height. I'll try to get some pics while in the shop today. I do have plans to build one of the dual indicator tramming gizmos though. Should make set-ups quicker.
  4. DMS
    DMS United States Active User Active Member
    16
    38
    City:
    Santa Clara
    State:
    California
    I use the same method as Terry.
  5. itsme_Bernie
    69
    48
    City:
    NNJ
    State:
    New Jersey
    Thanks a guys- and what if you have work on the mill table?
    Are there any tricks for this?
    I am quite sure I have a large bearing race around that I kept for this purpose, but I so rarely have the mill table completely empty.
    Bernie
  6. jamie76x
    jamie76x United States Active User Active Member
    3
    18
    City:
    Pittston
    State:
    Pennsylvania
    I always indicate right off the table.... Some times I lay a 8x8" piece of glass on the table so the indicator sweaps uninterupted...
    After a few years of working in a tool and die shop I tend to indicate everything. After I put a vise on my mill I will indicate it straight ad well as flat. I have seen many of vise not be true. When in doubt, indicate .
  7. Jericho
    Jericho United States Active User Active Member
    0
    16
    City:
    Kimball
    State:
    Tennessee
    Glad someone else had this epiphany. I realized how useful the glass would be for just such usage while cleaning up a mess from a broken storm window.i couldn't help but think float glass might be very close to the same dimension over a sq ft area and hopping those slots was a pain.And you don't have to get so precise on the centering like you do on a bearing race.
  8. RWL
    RWL United States Active User Active Member
    32
    28
    City:
    near Winfield
    State:
    Pennsylvania
    How thick is the piece of glass? ....or are you using plain window glass?
    - - - Updated - - -
    Where did you get a large bearing race like that?
  9. AR1911
    AR1911 United States Active User H-M Supporter-Premium
    90
    48
    City:
    Fort Worth
    State:
    Texas
    I made up a tramming tool with a 12" piece of 1" square aluminum solid.
    Arbor in one end (actually a caliper bolt from a Ford)
    DTI mount on the other end.
    Gives me enough reach to be REAL accurate.
    I happen to have a real nice piece of tempered glass about 8x30. It was a shelf.
    I have been sabving it, but I just now realized what I was saving it for!
  10. DAN_IN_MN
    DAN_IN_MN United States Active User Active Member
    2
    18
    City:
    Green Isle
    State:
    Minnesota
    Great post OP which developed great responses!
    Now, to find a use for the other 100 or so ITs we have hanging around!
  11. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,175
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    I have a new disc brake rotor I use to tram in the vertical head.
  12. high country
    high country United States Iron Registered Member
    1
    3
    I just sweep side to side on the table, then up a 2/4/12 block that I have.
  13. high country
    1
    3
  14. Billh50
    Billh50 Active User H-M Supporter-Premium
    704
    113
    City:
    New Britain
    State:
    Connecticut
    when I can't get low enough to reach the table because I have something mounted already. (This happens sometimes when you break an endmill and want to check the head before continuing. Anyway, I use 2 blocks (1x2x3 or 2x3x4 ) and tram from one to the other.
  15. high country
    1
    3
    A large block is super useful for this. I have a pair of 12" ground blocks and it's super easy to wipe the table, set the block on the table, extend the quill 100% and retract 100% while in contact with the block. Split the difference and double check on the table.....takes less time than anything else I've tried.
Share This Page
