Hello Folks,
I have a question on toolpost grinding: I am planning on making a light grind (.001 - .002 total) to true up the 10 degree taper in the mouth of my import 5C Collet chuck. I have fabricated a mount system to securely mount my Electric Die grinder on my AXA Phase II tool post. I will set the compound to the 10 degree taper, and then proceed with the grind.
I would also like to true up my 3 Jaw chuck by loading the jaws and grinding as well:
My die grinder is a simple chicago electric 25,000 rpm 1/4" chuck/collet die grinder.
- What is the proper "stone" to use for this process?
- How does one deal with wear/decomposition of the grinding stone during the grinding process?
IE: If I dial in .0005 of crossfeed, and start running the grinder (and grinding) into the mouth, how do I adjust for wear on the grinding stone - will the stone not decompose a measurable amount between the start and end of the grind?
thanks!
-todd
thanks!
-todd
