Hi shooter,
I'd also start at the beginning. Depending on the tube wall thickness, material, how it was manufactured, and how it is cut you may be starting off on the wrong foot.
- is the tubing manufactured by folding and welding? if so it may have a seam on the inside diameter that interferes with the plug you made
- are you crushing the tube in a vise when cutting it, making it out of round before even getting to the lathe?
- are you making it out of round with the cut alone? thin walled tube can easily be forced out of round with the force of a bandsaw or other blade. Also, they can throw up burrs on the edges that need to be dressed.
Try to eliminate any of those problems first.
Is there any way that you can mount your 3-jaw chuck in the tail-stock to help you align that end while you get the stead-rest roughly aligned? If so, you could:
- use the 4-jaw chuck in the head-stock grab one end of the stock holding but loosely,
- use the 3-jaw chuck in the tail-stock grab the other end of the stock again loosely,
- place the fixed steady where it needs to be again loosely,
- remove the 3-jaw tail-stock support
- dial in the tube at the steady rest as best you can, tighten without distorting the tube
- dial in the tube at the 4-jaw/head-stock, tighten without distorting the tube
- double check the centering at both ends
All the above is done without the lathe running, turn by hand to see the indicators move.
Temporary plugs may be required if the tube is so thin that the chucks or steady alone change it's shape.
Good Luck, and please let us know how it goes! (what worked, and what didn't)
-brino
