Since day 1 the 3 jaw Chuck on my 1127 has been very tight in regards to running the jaws in & out. I attributed this to it being new, but it's not got any better. I've removed the jaws several times looking for burrs, swarf, whatever that might be the cause. It really is a task to run the jaws in & out and with my old arthritic hands I often have to use both hands. I removed the jaws again today & finally discovered what I think might be the issue, but before I start filing, grinding, contacting Matt, or any other remedy, I'd love some opinions from others who have similar equipment.
Note in the picture below that each of the 4 valleys has a relief except the one in the upper left. All 3 of the inside jaws are like this; however, all 4 of the valleys on all 3 of the outside jaws are relieved. All 4 of the valleys on each of the 4 jaw Chuck jaws are also relieved.
It's the same valley on each of the inside jaws - like maybe a step was forgot on the set of jaws.
Would really appreciate if some of you would check your jaws and see if yours are the same. You can tell without removing the jaws from the Chuck as shown in this pic. Note the unrelieved valley is in the lower left.
