  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Tig welder
3
Like what you see?
10
abunai
Active Member
Active Member
Sep 16, 2017
45
Likes
21
#1
I've always wanted a Tig welder.
Have a Mig, Arc, and bottles.
Also have a plasma cutter.
Don't want anything big.
Alum, stainless, steel mostly.
No plan to weld anything thicker than 1/4"
I've tried to weld alum and stainless with the Mig, but did't like the results.
Suggestions on something under $1000.
killswitch505
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Nov 10, 2013
187
Likes
142
#2
I have a miller miller syncrowave 250DX and I really like it but....... realistically it’s probably twice or 3 times the machine I need for my hobby shop if I had it to do all over again I would probably give one of these a try I seen a bunch of YouTube videos they have really great reviews. I did the research a while back and it seemed like one model was far superior to the others I believe this is the good one.
2017 EVERLAST PowerARC 160STH 160amp HF TIG Stick IGBT Welder 110/220 Dual Voltage https://www.amazon.com/dp/B00H2VETB6/ref=cm_sw_r_cp_api_6cw8zbS3VGX39
It has a really small footprint and looks like it would be easy to wheel around on a cart
Groundhog
Jan 20, 2016
506
Likes
602
#4
I have a ThermalArc 200 AC/DC that I really like. I bought it quite a few years ago and it has been trouble free. It's a good, full featured inverter and came with everything but water cooling and a decent helmet (or any helmet). Had the option of a foot pedal or finger switch - I got the pedal. Nice steady arc (stick or tig) at any setting.
I see the price has gone up a bunch since I bought mine in 2009!
abunai
Active Member
Active Member
Sep 16, 2017
45
Likes
21
#5
The two Everlast are DC only.
Not what I'm needing.
Thank for the suggestion.
Thermalarc looks good, but more than I want to spend.
I'll see if I might find a used one.
BGHansen
Nov 23, 2014
727
Likes
1,618
#8
I have a 2016 model AHP AlphaTig 200X like DSaul mentions above. It has worked great for me. I've welded quite a bit of 0.036" steel, some 1/8" stainless and a few 1/4" aluminum pieces. I still need practice on the Al as my welds look like crap (on inside 90 deg. welds), but they hold. I'm assuming it's me and not the welder.
I've not had to service the welder so have no idea how well it's backed by the manufacturer for problems. I like that they continually keep improving the machine (at least 3 different iterations so far) which tells me they're not a "one-off" company. They've been around for at least 5 years and are still in business.
I bought mine off eBay for $680 including shipping. Bought a new 40 cf tank for around $200. Then spent at least another $100 on various tungstens, filler rods, torch tips, etc. Also a little over $100 for the mid-range HF welding cart. So totaled up a little over your $1000 target buy the cart and 8 or 10 different tungstens were more impulse buys than out of necessity.
Bruce
killswitch505
Nov 10, 2013
187
Likes
142
#9
Oops...... they make an AC/dc machine I know that’s what I had to be looking at a couple years ago
richl
Active Member
Mar 2, 2013
710
Likes
474
#10
Bruno and dsaul, the ahp machine sure comes at a very attractive price, as Bruno mentions, my concern would be servicing. It's taken me awhile to come off the lofty miller and Lincoln horse to even consider some of the affordable chinese imports. But that type of thinking comes with a high price tag, I'm adjusting .
Eastwood has a 200 series tug welder that some say is close to performance to the everlast, their service seems to be good... my local welding shop sell Forney machines, they are in the very attractive range also. With purchasing something from a lws, you at least have a brick and mortar shop to get service from...
Just some additional thoughts.
frugalguido
Jun 27, 2016
40
Likes
26
#11
I would highly recommend the HTP 221, it is made in Italy by Stel which makes industrial big welders. I love mine, it's comparable to the Miller Dynasty's 200 & 280. Mine is the 220v version, but they also have a 220/110volt version. HTP has very good support with long time employees. Check them out.
http://www.usaweld.com/ProductDetails.asp?ProductCode=70221-12.5
BFHammer
Jan 27, 2017
114
Likes
134
#12
I wanted to get into TIG and ended up after much research with an Everlast PowerTIG 200DV. (http://www.everlastgenerators.com/product/tig-stick/powertig-200dv). It was the right price point for me and has been a great machine. It's AC/DC and dual voltage. It does a great job on steel and I've recently started working with aluminum. Haven't quite mastered the aluminum yet but I have no doubts that the issue is me not the machine. Still using the stock pedal as it seems to have good control.
My first welder was a Millermatic 211 MIG - great machine which I love, however if I had bought the Everlast TIG first I would have taken a serious look at their MIG.
Just as a matter of contrast I also have a plasma cutter - I started out with an Eastwood and wasn't pleased. I eventually sold it and bought a Hypertherm - no regrets there other than the initial hit to the wallet!
royesses
Aug 23, 2014
497
Likes
410
#13
I don't have the AHP, but I have heard many great reports on it. I have a Lincoln square wave tig 175 that I love. For 1/4" aluminum plate 250 amps is not too much. The Lincoln cost twice what the AHP costs with none of the bells and whistles of the AHP and less amps.
abunai
Active Member
Active Member
Sep 16, 2017
45
Likes
21
#14
The AHP looks like what I'm wanting, but no shipping to Hawaii on Amazon.
HTP is to expensive for me.
Everlast 185 looks interesting. Wish it came with a foot peddle.
royesses
Aug 23, 2014
497
Likes
410
#15
Home depot sells them. Don't know if you have one in Hawaii they shoow $773 on the 200 TX model.
abunai
Active Member
Active Member
Sep 16, 2017
45
Likes
21
#16
Thanks for the Home depot suggestion.
Seems they will ship to the store for pick up free.
BUT....... The APH is out of stock:confusion:
I'll put in a request to notify and see what happens.
coherent
Active Member
Active Member
Aug 6, 2013
108
Likes
61
#17
I'll chime in with another +1 on the AHP Alpha Tig. No problems or issues except really didn't care for the pedal that comes stock with the machine. I replaced mine with an SSC Controls pedal they make for the Alpha tig. Much smoother and makes a world of difference. Highly recommended.
DSaul
Active Member
Active Member
May 18, 2014
69
Likes
77
#18
Yeah, the pedal seemed more like an on/off switch. I replaced the pedal with one from USA Weld and it makes a big difference. I also went with a smaller CK9 torch, because most of my work is with thinwall 4130.
royesses
Aug 23, 2014
497
Likes
410
#19
You may need to call home depot or email them. I emailed Lowe's and they called me withing an hour for my SQ175 Tig. They ordered it for me and chopped $1100 off the price. It took 7 days to get it. They were very happy that I called them and had a bunch of questions about what people want in the welder and torch products they can get. Very positive experience.
Roy
abunai
Active Member
Active Member
Sep 16, 2017
45
Likes
21
#20
Called home depot. Talk about dumb and dumber.
No one there knew anything.
According to them, they don't do that.
When I directed them to the website. they said I'd just have to wait until I get a email from them.
We'll see what happens.
More I resurch this machine, the more I like it.
richl
Active Member
Mar 2, 2013
710
Likes
474
#23
Apparently this machine sells out regularly at home depot, if you read the questions and answers section, one of the questions from 2016 was when they will be back in stock. They have had several shipments since, each selling out. Popular machine anyway.
Ironken
Active Member
Active Member
Feb 19, 2016
318
Likes
187
#24
I just jumped on the Hypertherm train after a few years with Miller plasmas. Never thought I would say this but, the Hypertherm is far better and I ordered it with the CPC port for my future cnc plasma table purchase.
abunai
Active Member
Active Member
Sep 16, 2017
45
Likes
21
#26
Good news.
Got a email telling me they were in stock again. I ordered one, but made a mistake on the address.
Waited up so I could call and have them make the change.
I called as soon as they opened at 6:00A.
It was 1:00A here.
Talked to a lady and she said the order is to late to cancel.
I put the order in at 9:00P.
I asked if she could just change the address. I had forgot to put all the numbers in it.
She said she couldn't do it until I get a email saying it was shipped.
I told her the address is wrong, and there is no such address.
She said when i get the shipped email to call back and they can make the change.
I hope she knew what she was doing.
Strange how I put the order in at 9:00p and by 1:00a the order could not be canceled.
I just hope it get to me.
Amazon is cheaper, but they won't ship to Hawaii.
outsider347
Active Member
Sep 3, 2012
254
Likes
12
#27
You need to go to the Welding Web forum to see what the real welders say about all things welding...that what I did!!!
On that note I just bought the new Vulcan Pro Tig 200 from HF and it works great.
Before all the haters chime in, a few FACTS that I learned
ALL of the welding machines I(Blue, Red, Yellow and everything else ) in this category are not made here. Probably China!
A guy (real welder) from Cali did the beta testing on the Vulcan and he says "every bit a good "operationally" as the Lincoln SW tig 200
To the coming questions from the haters "where ya gonna get that ***** serviced"?
Harbour Freight is offering a 365 day full refund for any reason. They are offering this to get the new Vulcans out
NO! I do not have anything to do with HF... Just a garage guy just like you
My2c
BTW I pd $799. for my welder
richl
Active Member
Mar 2, 2013
710
Likes
474
#28
I think you missed the point;)
A abunai asked about Welders, he lives in Hawaii. No one is slagging the vulcan Welders, I have also heard some reviews on it and seen somethings about it that seem like it's a good machine. There is a difference between the US brands and the overseas brand... yes, the parts are probably all made in china), but service, research and development and such is still done on the US brands. I have older miller and Lincoln machines, but my plasma, and tig will likely come from one of the newer overseas guys.. as you said, we are just garage guys. It's good to hear your point of view, a review would be awesome, as I said, I've seen some on utube and read forum posts, but there is nothing like getting the opinion of some real garage guys.
The vulcan is still a new machine, we don't know much about it other than the early reviews, the beta shop in California you mentioned and the typical review sites on the machine...
outsider347
Active Member
Sep 3, 2012
254
Likes
12
#29
Don't think that I missed the point at all....
The Vulcan as well as many other brands match the criteria that abunai presented in the #1 post
I only tried to present another choice
No idea if there is a HF on the island
Anyway, buy a tig welder. Awesome process to learn & use. Hardly use my mig anymore...Only for the big stuff
richl
Active Member
Mar 2, 2013
710
Likes
474
#30
My point is not that it is a bad unit, just that it is a new brand. Too soon yet to know if it is a durable unit. I kinda like the everlast brand, lots of great reviews, the ahp mentioned here was one I've seen, I did not realize it gets pretty good reviews. The 680.00 dollar area is amazing.
I thought about the vulcan, went to purchase one, hf did not yet have them in stock... than the ahp was brought up.... hmmm
[6]
5 [7]
