- Mar 18, 2013
- 29
I'm trying to cut a 20mm 2.5 thread on a Grizzly 14x40. You can see the results in the image below. I'm using an Arthur Warner HSS threading tool (60 degree tip). All gears and associated settings are correct. I keep the threading lever engaged throughout (thread, stop, pull out, reverse, thread again). The setup is rigid. Speed is 70 rpms. Compound is 29 degrees. Thread tool is properly set with a fish tail.
The "left" side of the thread is 30 degrees. The right is much more. Not sure what I'm doing wrong.
