That's only 2.5 degrees per thread flank. I buy off on threads with that much error in angles occasionally that hold far more loading than you could ever think about and are about the same size in diameter and pitch. If you ever put 15,000 ft/lbs of torque into the thread the flanks will bend and match up and break out every time. Run it! you'll never see the difference in use, ever! Ken
