Thin wall MT3 to MT2 adapter?
Alan H.
H-M Platinum Supporter
Sep 17, 2018
230
Is there such an animal as a thin wall MT3 to MT2 adapter? The Sioux adapter I have in my kit has a wall thicknesses of about 0.135". The adapter projects beyond the face of the tail stock socket about 7/8" when in place.
I was wondering if there's an adapter with a thinner wall that would take some of that projection away? Of course that means that the geometry of the back end of the adapter would need to be a bit different as well. I am thinking this is all feasible and wondering if someone makes it.
I think it is time you make one. :encourage:
I would not think that something like that would exist commercially. Although, I have been known to be wrong countless times before.
They indicate the Z-Live sleeve measures 2.5" so is shorter than the taper section on a MT3. So should work as opposed to the adapter sleeves with a tang.
Outside Morse Taper 3.
Inside Morse taper 2.
Made of high quality alloy steel hardened and ground throughout.
Overall Length: 2-1/2".
Run out: 0.0001"
http://zlivecenter.com/02010MT32
Thanks Mark, I had seen the sleeves but was uncertain as their wall thickness. I called Z Live Center and asked and they say it will project less than the tang end adapter. I must say there was a bit of a language barrier and I am not sure I was able to explain it well enough and felt I may have lead them to the answer I was after.
It's worth ordering one and seeing how it works. The length should definitely help on hang out compared to an adapter with a tang. The adapter with a tang gets expelled from the tail stock at about the 7/8" projection mark. The sleeve will help preclude that at least. It may still hang out a bit but at least it will eliminate the earlier touch down with the tang adapter.
EDIT: Have one coming now..
Run out: 0.0001"
So this one is a thinner sleeve than standard?
Randy, I doubt the actual wall thickness is any thinner. The gent at ZLC said it was but like I said I think there was a big language barrier in the way.
What it will likely accomplish however is allowing you to keep the tailstock retracted deeper into the housing since there's no tang.
I should have it on Friday (EDIT: Monday) and we'll get a confirmation one way or the other. I will post some photos of the two different adapters in the tailstock.
Meanwhile I should seize the opportunity to buy a toolpost grinder so I can grind it down shouldn't I??
The type of sleeve that Mark posted a pic of from ZLC is not any thinner, it's shorter, much shorter than a standard sleeve. The center you put in it might be longer than the sleeve. They project less cause those sleeves are the type that are used in the headstock spindle. I have one of thise in a MT5-MT3 from ZLC, the one that came with my lathe wasn't that great.
I wouldn't use of those in the tailstock. Because it has no tang, when you try to eject it with the tailstock handwheel, you risk ejecting the center out of that sleeve & you'll have to figure out a way to eject that sleeve. If you have a slot in your tailstock quill for a drift, that still may not work as these sleeves are shorter.
If that's all you want you can simply cut the tang off. That's what I did for my drill chucks that I use on my lathe to get the full travel of the quill. On my live centers that I use sleeves on I don't really care cause most of the time I have to extend the quill to use them but I cut the tangs off anyway (still need to do one more). My tailstock does not have the slot for the tangs so it doesn't matter to me.
Thanks Will. I don't doubt at all that it is not thinner. We will find out 'cause it has been ordered and will be here in a few days.
I will carefully check out the dimensions and issues you point out before jamming that baby in there too tight.
