    Dismiss Notice
The Pm-1440gt Has Landed
Discussion in 'PRECISION-MATTHEWS' started by jbolt, Sep 9, 2016.
  1. jbolt
    jbolt United States Active User H-M Supporter-Premium
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I got the machine switch labels done and installed. Labels are made from 1/16" matte silver engraving plastic.
    Almost done!
  2. tmarks11
    tmarks11 Active User Active Member
    181
    43
    City:
    Port Orchard
    State:
    Washington
    -Return to Top-
    nice! You do great work.
  3. MonkMan
    MonkMan United States H-M Supporter - Premium Content H-M Supporter-Premium
    71
    28
    City:
    Monkton
    State:
    Maryland
    -Return to Top-
    Nice! Better than factory made.
  4. Sendit
    Sendit United States Active Member Active Member
    57
    18
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Very nice! What engrave did you use?
  5. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I did these on my CNC router with 1/16" and 1/32" end mills.
  6. catoctin
    catoctin United States Active User Active Member
    28
    28
    City:
    Pleasanton
    State:
    California
    -Return to Top-
    What brand CNC router? I am looking for one for some planned work in the future.
  7. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I designed and built the CNC router. The build log is here.
  8. Sendit
    57
    18
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Awesome! Have a build thread for it?
  9. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
  10. Sendit
    57
    18
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Sorry, it wasn't showing up on my phone. Thank you.
  11. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Well that figures. No worries, I hope you find it useful or at least mildly amusing.
  12. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Worked on the spider a little tonight. I started roughing it out from a bar of 3-1/4" A36 hot rolled steel.
    This is the largest steel stock I have done on this lathe so far and hot rolled is not my favorite but I had it on hand. All I have right now is some general purpose carbide inserts. I am a little blown away at how well it machined. This was at 600 sfm (750 rpm) / 0.01" feed rate and a 0.05" DOC. It could definitely take a deeper cut with ease.
    Third and final pass at 0.025 DOC. 800 sfm (1000 rpm) / o.o1" feed rate. Cut was +0.002" over my target of 3" without really trying to be too precise. The finish is close to a 220 grit. I can't wait to see what it will be like with the proper insert.
    After cutting off the turned end with the band saw to a little over the overall length I faced the ends to size and started roughing out the bore. First drill was a 1/2" followed by a 1", the largest have. RPM was 250. The new motor is amazing with the RPMs holding rock steady no matter how hard I feed the drill bit. The factory single phase motor growled a lot with heavy drilling in aluminum.
    Cutting steel on this machine is like cutting aluminum on my old one. Makes me smile.Very cool!!!
  13. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I have a question for the PM-1340GT owners. What is the actual cross slide travel on your lathe? My 1440GT is speced at 7-1/2" but the actual travel is only 6.4".
  14. mksj
    mksj Active User H-M Supporter-Premium
    1,365
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Hi Jay, looking mighty nice, and beautiful finish for the feed rate. Going 3 phase with a good motor and a VFD, world of difference. The trigon and the 80 degree rhomboid inserts are go to cutters. Travel on the PM1340GT cross slide is 6.5".
    Mark
  15. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Thanks Mark. I'm a bit annoyed at the less than advertised cross slide travel. I confirmed with another 1440GT owner that his was the same as mine.
  16. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Here is the completed spider. The fit to the spindle came out perfect. The spider is locked to the spindle with 3/8-24 flat bottom set screws so it wont mar the spindle. The clamping screws are also 3/8-24 but in stainless steel with 1/4" brass tips.
    The mods I did to the cover allowed the upper stud that holds the belt cover on to be reduced in length as well as the thumb nut. The clamping screws will now clear the thumb nut so the spider can be used with the cover on.
    Turning finished
    Spider installed. Note the recessed magnet for the tach sensor.
    Completed spider. Clamping range is 1/4" to 2"
    BGHansen, Sandia, bss1 and 6 others like this.
  17. Dan_S
    Dan_S Active User Active Member
    546
    93
    City:
    Champaign
    State:
    Illinois
    -Return to Top-
    Are you measuring total travel, or just on the one side of the center axis?
  18. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Total physical travel.
  19. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Here is the start of the next two projects for the lathe, the proximity sensor mount and a rack for the QCTP tool holders.
    This is the front plate that holds the P-sensor to the micrometer stop. The milling was done on my PM-932 CNC conversion. I was going to thread mill the p-sensor hole but decided to use the lathe. To cut the 1mm pitch thread I had to change the upper gear from the 30T to a 28T and move the lower 60T gear to the 120T center gear.
    The upper and lower gears are held in place with a 6mm socket head cap screw and the center idler gear is adjusted at two locations with a 17mm wrench. The gear changes are fairly quick taking only a few minutes. Having to remove the belt cover to swap the gears made me miss my old lathe that had a hinged cover. The gears and spacers are broached with a key-way. The broached area is rough from the factory and needs a little dressing up to remove the burrs so they will slide on and off easily. Before I de-burred the 60T gear I had to remove it with a gear puller.
    Being able to use the forward and reverse jog makes metric threading, where you can't disengage the half nut, a breeze to do.
    Here are the QCTP tool holder holders. :confused:
    They will be mounted a piece of 1/2" x 1" 8020 t-slot extrusion attached to the back splash. The holder base is made from 3/8" x 3/4" aluminum bar. The back side is machined to create a boss that keys into the 8020 slot so they won't pivot. The tool holder captured by two 1/4" dowel pins are pressed into the top of the block.
    MonkMan, Sendit and wrmiller like this.
  20. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Tool holder rack finished.
    wrmiller, sgisler, MonkMan and 2 others like this.
  21. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Made some new handles to replace the plastic ones.
    handle02_resize.png handle03_resize.png handle04_resize.png handle05_resize.png handle06_resize.png
    richl, zmotorsports, Lonnie and 6 others like this.
  22. Mr Magoo
    Mr Magoo United States Iron Registered Member
    17
    3
    City:
    Palmerton
    State:
    Pennsylvania
    -Return to Top-
    Very nice. I'll send you some stock for my set. Lol great job
  23. wrmiller
    wrmiller Chief Tinkerer H-M Supporter-Premium
    980
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    Oooh...purty! :D
  24. TomS
    TomS Active User H-M Supporter-Premium
    433
    83
    City:
    Redding
    State:
    California
    -Return to Top-
    Those are nice!!!
    Tom S.
  25. Mr Magoo
    17
    3
    City:
    Palmerton
    State:
    Pennsylvania
    -Return to Top-
    Not quite as fancy as yours but I liked the idea
    Fitter Bill likes this.
  26. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Looking Good! The polish is a nice touch. What did you use to do that?
  27. Mr Magoo
    17
    3
    City:
    Palmerton
    State:
    Pennsylvania
    -Return to Top-
    400
    600
    1200 paper
    Then mothers aluminum polish on an arbor
    jbolt likes this.
  28. Lonewolfgun
    Lonewolfgun United States Swarf Registered Member
    0
    1
    City:
    Manning
    State:
    Iowa
    -Return to Top-
    JBolt,
    Looking at your pictures it looks like your only using leveling pads to level the lathe. Did you have any troubles with getting it level and now keeping it level using on the pads?
  29. jbolt
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    No issues with leveling or keeping it level. The machine is very easy to level and true. The final tweaking is done with the lock nuts on the leveling pads.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  30. dr.diesel
    dr.diesel United States Iron Registered Member
    9
    3
    City:
    Terre Haute
    State:
    Indiana
    -Return to Top-
    Hi Jay,
    I can't tell from the picts, are you using BXA QCTPs?
    Thanks
Share This Page
