[Lathe] The LeBlond Gets a companion.
Looks like a four on the slide too. Another flat belt drive unit covered in blue.
Looks like you have your work cut out for you. Interesting chuck on there, never seen one quite like it. Mike
The Brits sit the water a little different than other ducks. It is surprising shape foe a nearly 100 year old lathe. My plan is to remove the rust from the ways and use it like it is.
