Looks good, Nelson.
While it's nice to have lots of power available, you are well advised to only use wire that can handle that current to feed a machine. A 30 amp breaker won't 'force' 30 amps into a load, but, if a fault occurs, it won't trip until the current exceeds 30 amps. If you used #16 wire (power cord, extension cord, etc.) to connect the machine, a couple of things could happen. As the load passes 8 or 10 amps, the voltage getting to the machine will drop and the too-thin wire will start to heat up. The heat will cause more resistance, increasing the losses and the heating.
