The digital readout, which is a Teledyne-Gurley Pathfinder 50, has the "X" axis reversed. Positive showing negative / negative showing positive, on the readout. The scale is mounted on the front of the mill and not the back. Does anyone have a readout of this type and how do I re-calibrate it to show the correct direction? I know most readouts, you can switch between -/+, but I cannot figure this one out.
