I know this is a common/difficult subject on these mini lathes. I got mine all dialed in where I was happy, left it over night, came back and took another cut on a new centered test bar just to see if it was still good and it was out .003" over 3 inches.
So I dialed it back in, cut 3 test bars in succession and each one is anywhere from .0005" to .003" out. Why is it that this is not repeatable?
I have done all the mods to get it really dialed in with extra set screws and moving the bolt to the top side. In ALL of the above cuts I did not move the tailstock at all, just the ram - being careful to tighten the center against the test bar the same amount each time. There is no runout on the ram, on the inside of the bore, etc - all is right on. The headstock end also does not runout. Lathe is new, bearings are good, etc.
I did get really good at aligning it with a dial indicator anyway .. carefully moving it over .001" at a time after test cuts, and watching the dial indicator for movement when tightening everything back down. I have tested all of this using centers .. both live and dead in the tailstock and dead in the spindle.
Any other ideas or things to look for? I have never had any problem on a real lathe, just this crappy casting used for the mini lathe tailstock.
