Not sure about doing it that way. Your three jaw is not going to be aligned with the bore of your lathe so you will just align the tail stock with the three jaws axis not your lathes axis.
Sorry, but no I don’t think so, at least not my test indicators. Yes, gravity can effect an indicator if you drop it on the floor! But to have the reading change because gravity pulls on the stylus/probe??? If there was any change in the reading, then IMHO it’s probably due to lack in rigidity somewhere in the total indicator set-up and not gravity pulling on the stylus. However, when using a test indicator you can get readings that are not quantitative. 1) Using the stylus at an angle other than from its true origin (straight out) will cause cosine error in the readings. 2) Using a stylus with a different length other than the calibrated length. If you are using the test indicator just for comparison readings, as in this authors example, then the above 2 concerns do not apply. And the top and bottom readings do not apply as well…Good Luck, Dave.Two things, Dial indicators and the coax indicator are affected by gravity. When a dti is held in a horizontal position and you sweep your tailstock the top and side readings will be correct. The reading on the bottom can be several tenths off do to gravity pulling on the probe. Richard King always suggested chucking up a piece and turning to the exact dia. of your tail stock spindle.Do not support it with a center, just turn about a 6" long area. You then put your dti on the top of the turned piece and then move the saddle towards the tailstock and traverse the top of the tailstock and do the same on the side. This give you your readings for height, side to side and parallelism of the tailstock. This is of course, after assuring that your lathe bed and headstock are aligned first. The above posters are correct though in that your coax may get you close enough. Depends on your requirements.
Darrell
