4
Taig Micro Lathe Rust
3
Like what you see?
10
JohnnyTK
So New Still Setting Up Shop!
H-M Supporter-Premium Member
Jan 20, 2017
14
Likes
4
#1
I will be purchasing a second hand Taig and the owner says it has some surface rust(no pitting) from sitting in the garage for the last year. Any suggestions on how to remove this rust? Will be seeing it on Tuesday.
JohnnyTK
Jan 20, 2017
14
Likes
4
#2
It was suggested to use 0000 steel wool with WD40. Not sure if this is the best method, being a newbie.
mikey
Dec 20, 2012
3,034
Likes
2,954
#3
Depends on how much rust there is. Light surface rust will usually come off with WD-40 and a 000 gray Scotchbrite pad. I avoid steel wool because any residual particles will hide in cracks and crevices and rust. You can also try some Phosphoric Acid prep. I use the Must For Rust and it works really well. If you want every bit of rust out, use the Electrolytic Rust Removal process and that will work the best. A light scrub with a gray Scotchbrite pad afterwards and you're done.
compsurge
Active Member
Oct 27, 2014
276
Likes
31
#4
WD-40 and maroon Scotch Brite works as well. If you are going to keep it in similar environmental conditions, you will want to spray it with WD or coat it in a light oil to prevent it from reoccurring.
chips&more
Active Member
Mar 19, 2014
2,041
Likes
1,372
#5
Welcome, I would first try just the WD40 and rub it with a rag and see what happens. I would avoid any abrasives until you have exhausted all other options. If you do use an abrasive be mindful of the scratch pattern that will be left behind. You might want to go with the grain kinda thing. On another note, I would NOT leave WD 40 on bare metal for any great length of time. It tends to rust the metal instead of protecting it from rust…Dave
dieselshadow
Do you smell something?
Aug 21, 2016
171
Likes
158
#6
Wd-40 causing rust instead of preventing it? I've never seen that before.
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,404
Likes
2,665
#7
Yep, it sure will. Especially if you live in a high humidity region of the country. WD-40 is banned from my shop. Suggest coating with a ISO 32 or 46 hydraulic oil. Ken
Groundhog
H-M Supporter - Premium Member
Jan 20, 2016
505
Likes
599
#8
Lots of info & products here; https://www.theruststore.com/ . Several good articles and comparisons.
I used "Rust Release Super Gel" on my HF lathe (that sat idle for years and had a little surface rust) with a little Scotch Brite and was very pleased. It works just like "Evao-o-Rust" that everyone seems to like so well, but it is a gel and will stick to vertical sides. (Caution: As per instructions -- DO NOT let it dry out -- it leaves weird stains in the metal).
Hidyn
Active Member
Active Member
Nov 4, 2015
31
Likes
21
#10
What's this rust stuff all you guys are keep talking about?
High and dry in Colorado
Definitely one of the perks to living in the desert! Great for my machining and firearm hobbies, not so much for my gardening... :(
Quattroclick
Iron
Registered Member
Jan 25, 2017
17
Likes
11
#11
Stuff rusts here too, just takes longer. I have been cleaning surface rust off my new (to me) Bridgeport with CLR and maroon Scotch Brite. A little CLR goes a long way. Smaller items have been going into a bucket of apple cider vinegar. Both seem to work well, and are cheap.
6
5 7
