  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Table Oilers for G&E 16" Shaper
3
Like what you see?
10
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#1
I have a G&E 16" "Industrial" Shaper that I need to get back into service. Someone cut the electricals from the motor to the shaper, but that will be a different can of worms.
I just dipped out 5+ gallons of what looks like motor oil from the base of the shaper and plan on refilling with diesel fuel to clean out all the lines etc. To get to the point: On the rear section of the table there are 2-oilers, the one on the right has a hose coming out the top with a copper tube that has been crimped shut. Can anyone let me know how the lubrication for this part of the shaper is supposed to be run?
You can see the access hole that is on the back side of the table support, it has a hose going into the main base of the shaper and is attached to the oil system. What is marked Left Oiler is directly above this area with the rubber hose w/crimped off copper end. At this point I would just want to get the shaper running. Paint etc. will be well down the road.
Mike
4gsr
HM Chief Foreman
Staff member
H-M Supporter-Premium Member
Aug 8, 2011
4,409
Likes
2,667
#2
If I had to guess, they crimp off the end of the tubing with a very small opening that would allow a small drip directed to the column way. Unfortunatly, this stuff gets damaged and removed over years of abuse and neglect and never gets fixed. Is there a oil pump some where on the machine that feeds this line as well as other lines on the shaper? How about some more pictures? Ken
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#4
Ken, let me know what additional photos would you like to see and I'll try to get them.
Daryl, I've not see that manual before, thank you for posting. I don't see this area in the lube diagram, it appears to me that they are more concerned with lubing the ram.
Ken's comments made me wonder. I originally thought that the hose with the crimped copper tube on the end was something that was added; but now MAYBE there should be a similar hose with copper tube in the center lube location that is now missing. each hose/tube is to lube the vertical column. This idea looks like it would make sense.
Am I/we on the right track?
thanks again guys for helping me out; keep the ideas coming.
Mike
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,409
Likes
2,667
#5
I was thinking pictures of the oil pump, junction station where all of the oil lines branch out from. The oil filter, unless its a Cunio filter.
The manual Daryl posted only shows oil cups at these locations. I wonder if this was a factory update or if it was something that someone added over the years?
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#6
I'm working this weekend so can't do anything in the garage. What is a Cunio Filter?
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,409
Likes
2,667
#7
It's a mechanical filtering unit that is operated by turning a handle mounter on the unit. The Cunio unit is mounted flush on the machine housing, somewhere. I'll see if I can find a picture of one. Ken
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#8
I finished draining the oil and found a thick whitish goop on the bottom. I tried to loosen it up by adding diesel. Here are some photos
I think this is the filter attached to a housing that I assume has the pump.
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#9
If you look to the right of the chain you can get a glimpse of the top of the box that I assume is the pump housing. You can see a fitting with a copper oil line.
The diesel broke up a lot of the "goop" I think I need to use a more aggressive solvent but I don't want to take a chance on damaging anything. Any advice?
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,409
Likes
2,667
#10
Run some Naptha thru there followed by more diesel or mineral spirits. Your not going to get it completely clean. Boy! If that pump goes down, that would be a nightmare to pull!
rrjohnso2000
H-M Supporter - Premium Member
Sep 19, 2014
218
Likes
78
#11
White goop is likely water in oil suspension. If interested in determining you can just heat it above water boiling point. Water leaves and oil is left
If water is in the system maybe try some alcohol to dry it out
Good luck
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#12
I agree that the white goop is water in suspension. The diesel emulsified a lot of it and I was able to vacuum it out. What is left seems to be either semi hardened or sticky. I want to get as much if not all of it out before turning the shaper over by hand. I don't want to take a chance of picking up any of this crap and clogging the pump/filter or lines. I don't know how many years this machine sat in a museum's unheated RR shop unused and unloved. I've had it for a few years myself---no excuses for not getting this up an running sooner. I am considering jacking up the rear of the shaper and putting a gallon or so of solvent in the sump and letting gravity help bring the goop away from the pump.
Please keep the ideas coming.
Mike
rrjohnso2000
Sep 19, 2014
218
Likes
78
#13
If it was me. I would fill the sump with diesel/ kerosene and just let it sit, a couple weeks or so. Then I would pick my favorite degreaser and wash it out. Pump all the water out and then another kerosene wash
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#14
Just to give a little update, sump is soaking in Diesel. I'll let it go a few more days before trying to scrub the crud out.
I rearranged some machines in the garage today. That shaper is one heavy son of a gun to move single handedly.
Mike
Glenn Brooks
Nov 14, 2014
651
Likes
665
#15
Reach down in there with a long metal prob. Maybe something made out of 5/16 rod with a small bent scraper ground, bent or beat into the end. You can scrape a lot of crud loose this way and scoop it out. Also, I often stuff pieces of oil absorbent towel down into crevices and scrape, probe, otherwise finesse this kind of junk free from oil sumps. Sometimes a long flat head screwdriver works just as well. Always flush a couple of times with diesel to drain/soak it up with absorbant pads. Works great usually!
Running the machine with a diesel flush for 15 -30 seconds also cleans a lot of junk out of gears and assorted machined surfaces.
Glenn
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#16
Glen, Great minds think alike :)
Yesterday after I moved this beast to the get it in a better position for use and wiring it up to 3-phase and was looking around for various implements to do just as you suggest.
QUESTION:
Does anyone know if the oil pump will pump when the trans is in neutral???
In the manual that Daryl (Uglydog) posted it seems to say that the ram must be moving to the pump to operate, this manual is from the 1930's. On the other hand, the 1960's Army manual for Mitts & Merrill machines appears to say to power up the shaper in neutral until you have oil at the ram sight windows.
Can anyone identify the year built from the serial number? G& E serial #3206A4
Mike
Kernbigo
Active Member
Apr 8, 2012
629
Likes
154
#17
not to long ago i opened restrictors on a surface grinder using (Krano Kroil penetrating oil) the best stuff in the world
Silverbullet
Active Member
Active Member
May 4, 2015
2,359
Likes
1,067
#19
I would guess the machines hydraulic driven. Not mechanical? That would be the only reason to run it and let it warm up the oil and get it pumping thru the lines. Pretty sure your pump will only work when the rams moving. Did you turn the motor on and Ck for oil in the lines? More pictures of the whole machine may help.
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#20
This is definitely a mechanical shaper, not hydraulic. The electricals have been cut is several places. So, no cannot attempt a start yet. I wanted to clean decades of dirt and grime off of everything prior to trying to run it.
I'm going to let it soak a while longer and try to get in under the gears and shafts to pull all the trash out and then I'll find a way to fire it up for testing.
willthedancer
Active Member
Active Member
Jan 23, 2017
228
Likes
168
#21
I have serviced many G&E gear hobbers. As manufacturers go, the quality was exceptional.
Their typical oiling systems used copper tubing throughout. They would crimp the ends in places to restrict the oil flow to an area at times.
It should be clear in the service manual if the driven sheave drives the oil pump directly, or if it's on the first shaft. Their hobbers did not run the oil pump from the sheave.
If I were to buy a shaper today, I'd be looking for one like yours. Nice machine
The fact that there is oil emulsion in the reservoir tells me that they didn't service it, maybe ever. Check your oil lines for leaks and areas where the copper is wasted.
Sent from my Moto G Play using Tapatalk
benmychree
John York
Jun 7, 2013
999
Likes
566
#22
I have a 20-24 G&E industrial universal shaper, dates to late 1950s; it has the same oiling system as yours; the pinched down tubes deliver oil to the wells and the surplus runs back into the base through the standpipes in the center, and wool wicking is used, pushed into the holes that lead to the ram ways; pack more into the holes to reduce the amount of oil delivered. On mine, I am relatively sure that the pump runs all the time the motor is running. Mine has an electric clutch / electric brake instead of the normal mechanical friction clutch.
A 20 /24 is basically a 24" stroke on a 20" frame machine, thus, lighter and less bulky than a straight 24. I assume you have the clear plastic covers that cover the oil pockets?
Reeltor
Active Member
Nov 18, 2014
737
Likes
308
#23
I am missing a few of the plastic sites that cover the oil pockets and will have to make some. Most of the oil pockets were missing the packing, the packing that was there are just strips of cloth. Thank you for the info that the wicking should be wool. Do you have any info on the layout to oil the vertical and horizontal ways for the table movement? One wiper holder is missing with just a rubber hose with a copper tube in the end just flopping loose on the table.
I'm working on the motor and wiring, hopefully it wont be too long before I see is this runs.
Thanks again for your help and info.
Mike
benmychree
John York
Jun 7, 2013
999
Likes
566
#24
I have the manual for mine; I will see if we can scan the relevant pages and send to you.
Send me a PM with your e mail address.
John York york@napanet,net
[6]
5 [7]
