Super Bowl Trophy
Fabrickator
Jan 22, 2014
578
I recently started my next project which I've been contemplating for some time now, deciding if it would be possible to make a scale model of the trophy by hand w/o CNC. I enjoy challenging myself with projects that are out of the ordinary and utilize all of the tools at my disposal. Since football has started up again, what better way to start off the 2014 NFL season than by making the ultimate sculpture. I did a lot of research, found some great pics and a rough, nearly illegible blueprint for Tiffany’s original Vince Lombardi Trophy, the iconic Super Bowl Trophy. One thing that stands out is the football looks large for the size of the base. During my research I read that it was designed on a bar napkin over drinks and it’s a full-size football that is mounted to resemble the ball in a kicking tee.
Factoid: The real trophies stand 22” tall, weigh 7 pounds and are made of sterling silver sheet metal.
I started by scaling the project to ¼ scale using dimensions from the blueprint and I devised a plan of attack. It turned out that to make the compound triangular base I could whittle it out of some 2” X 2” 6061 aluminum bar stock I had left over from my Turner’s Cube if I used an off-set center and a 4-jaw chuck. For the football I used a 6” piece of 2” 6061 aluminum round bar that I purchased.
Primary machines & fixtures:
Grizzly G0602
LMS Hi Torque mini Mill w/ power feed, rotary table & tailstock
Steve Bedair design Ball Cutting fixture & angle vise
One of the big challenges was how to make the compound triangle base. After measuring the bar stock I prepped and trued it by turning ¾” X ¾” off-set tenons at each end w/centers. At the same time, I drilled a #7 hole in the bottom and tapped it to ¼” X 20 TPI to eventually mount it on a stand. I drilled the top with a 3/16” drill to eventually mount the football.
Then I mounted it by the bottom tenon, horizontally in my rotary table on the mill and wedged one side up to the appropriate angle. I supported the top end with a rotary table tail stock in the center hole. I used a 5/8” 3-flute roughing cutter at about 1000 rpm @.100” per pass using a 45% auto feed rate. Because it produced many odd angles turning a square into a triangle it didn't look like it would ever come together. After the initial “knock down” of the copious amounts of waste, I rolled it around in 120* increments taking down a little at time off all 3 sides. It eventually came together per my drawing proving that the math doesn't lie! Before taking it out of the chuck, I cut 3 flats on the bottom tenon (between the jaws) so I could easily/accurately orientate the sides for some other operations later on.
For the football, I did the same prepping truing my 2” round bar. I trued up the OD to 1.875” and the length to 6”. This time I made the tenons .750” X .500”. The reason is I planned on shaping the football with my Ball Cutter and it needs room for tool swing and clearance. I cut the clearance area to ¼” X .750” wide with an outside radius which I hoped would still provide enough support. I cautiously approached the shaping by cutting very slowly with very light cuts (.010”). Because of the large radius (4”), I had to make several adjustments moving the tool outward while bringing it in to shape and diameter. I stopped short of taking off the mounting tenons because I still needed a way to hold it for several remaining operations. Once I hit the scaled dimensions, I sanded the piece while I could still spin it true.
I wanted to cut the radius in the sides of the base but found that my mill doesn’t have headstock clearance to cut it vertically with a standard fly cutter or boring tool, so I used a 3” drum sander with the base mounted in my angle vise. I started with 180 and finished with 320 grit paper.
I then did a preliminary buff the two pieces with my 10” 3-stage buffing wheels starting with Tripoli and then White Diamond.
I get a bit side tracked here because I need to stop and make a fixture for my ball cutter that would hold my flex-shaft pencil grinder. My idea is to use the Ball Cutting fixture on the mill table with the pencil grinder and appropriate bit, to swing/cut the seams of the football @ 90* increments with the ball in the rotary table.
Still a lot of detail work left to do. Mount the ball, make a base and even some engraving.
IMG_1038.JPG IMG_1040.JPG IMG_1045.JPG IMG_1063.JPG IMG_1095.JPG IMG_1139.JPG IMG_1142.JPG IMG_1147.JPG IMG_1148.JPG IMG_1154.JPG IMG_1156.JPG
Wow, very nice work, so far so great! Can't wait to see more!
Really impressive! Nice write-up too. Will stay tuned to see how it comes along ~
I originally planned on mounting the football in the rotary table and tail stock on the mill table to make the seams in the football with my ball cutter, but I've since changed my plans. I decided that it would be much easier and a more accurate set it back up in the lathe, but the problem was I didn't have any way to index the part. The following day I was researching the topic of indexing on lathes and found a web post where someone commented about a possible easy way to do it if your lathe has an external bull gear (spindle), which my Grizzly G0602 has. If the gear has an amount of teeth that is divisible by 360* (mine has 40T.) and can provide the degrees that you need (I need 90*’s) then all you have to do is make a pawl to engage it. WOW, great idea! Check out this link to see the details of this mod.
http://www.hobby-machinist.com/show...indexing-amp-Spindle-Lock?p=235207#post235207
I also made a few more refinements to my pencil grinder adapter mounting system and shaved down the tool holder a bit.
This pic shows a small test piece I made to prove the fixture will work when I mount the football.
Just reading this. Amazing work. Can't wait to see Tiffany finished!
I worked on the ball cutting jig this weekend to cut the seams in the football. As usual, I ran into some more unforeseen problems with swing clearance of the pencil grinder. What I ended up making was a longer tool holder because the length of the grinder tip compromised the ability to make the 4” radius with the standard length tool holder. Also, chucking the part on the turning tenon as I had planned placed the football too close to the chuck, so I drilled a 5/16” hole in one end, made an extension rod and epoxied it in. Since I’m not turning at speed, it worked fine. All I needed was some way to move the part closer to the middle of the bed for clearance, and provide a sure lock to the part for indexing.
After finally getting all of the pieces and procedures in place and the part centered correctly, I started making the cuts. They went really smoothly taking them in .005” increments to .016” deep. The indexing pawl system worked great with easy & accurate adjustments. It only took me about ½ hr. after all of the planning and setup work was done. I gave the part a quick polish and found that the seams look very life like.
I also figured out a set up to make the all important operation, setting the angle that the ball mounts on the post (48*). There was not much to hold onto but the round turning tenon at one end of the ball and so I added a support system for the upper end to keep it from moving/flexing while I spot milled and drilled the hole for the mounting pin. I used a tower of saw tooth setup blocks and my adjustable mill stop to apply downward pressure. it was very steady and turned out great.
Rick
