- Mar 3, 2013
- 1,448
Split phase motors are not the best choice for high starting loads.
If you are still interested in 3 phase you may want to check out the Leeson E116738 it's an OPD (open drip proof) rather than an TEFC (totally enclosed fan cooled) but it has no exterior junction box or capacitor. 3/4 hp.
Here is one site that has it: (I have never purchaased from them so I can't recommend or discourage)
http://www.electricmotorwarehouse.com/3-4-hp-1725-rpm-56-frame-208-230-460-volts-open-drip-leeson-electric-motor-e116738/#sthash.1O3tPpV0.dpbs
Drawing with dimensions:
http://www.leeson.com/CnxDocRequest/PublishedPDF/2015/documents/SW Drawing_607-0191_B_1898148_20.pdf
Here's a close up of a Leeson with a capacitor and the position of the J-box with respect to the ear on the casting. The motor is already padded up.
This particular setup is not using the stock pulley (someone bushed it for a 1/2 inch shaft, and the setscrew is stuck - still have to fix that). The motor will have to be nudged to the right a bit once the proper stepped pulley is installed.
This is a frame 56 Leeson Cat No. 110013.00, Model C6C17FB2K. I believe they're available on line for about $230. It's 120/240 single phase, but no thermal overload. I got lucky and picked it up NOS for about $100.
I happen to have a piece of small angle iron (future light mount) in the vicinity and it appears there's still a bit of room left to let the motor swing up more. Sort of tight, but it does fit.
Hope this helps.
TomKro
I agree with Rich. With all of the belts and gears that may be in the drive train, an engine lathe is not a good candidate for a split phase motor. Also try WW Grainger. They aren't cheap but do carry a lot of different capacitor start motors. One word of warning - if you do buy one with a thermal overload breaker, do NOT buy one with automatic reset. It will re-start itself as soon as it cools off.
Are the starting loads all that high on a 10" Logan?
Thanks for the info on overload breakers: I didn't know that. Do you think thermal protection is needed in a application like this: it's not clear to my why these motors would run hot.
(Though I understand that can be a concern with running at slower speeds with a VFD.)
