Strange end mills
Hukshawn
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Nov 19, 2016
755
Likes
474
#1
Never mind the chowdered ends, one flute is wider than the other.
I've never seen anything like that before.
Rummaging through the box of goodies that came with my mill.
I assume they are for aluminum?
Hukshawn
Nov 19, 2016
755
Likes
474
#3
Yeah the picture was hard to take.
They are not hand ground that way. The chisel point is actually off center.
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,399
Likes
2,657
#4
It's ground like that, so it acts as an wiper from the one longer end cut. Rather it works that way or no, I don't know. I've seen a few of them in my past, not a popular grind. Easy to fix if you know someone who is set up to regrind endmills. Not something you want to fix by hand.
Ken
Hukshawn
Nov 19, 2016
755
Likes
474
#5
They went into the garbage with a pile of other broken dull crap.
I have to be conservative with my small garage shop.
timmeh
isdownthashed.
Active Member
Aug 23, 2014
74
Likes
17
#6
Nothing wrong with them, Slot Drills are supposed to have uneven cutting edges.
British Steel
Active Member
May 12, 2011
691
Likes
517
#7
What Timmeh said, it's so they can plunge into the work without a pilot hole when slotting, fish them back out of the trash!
The centre doesn't cut brilliantly because SFM drops to zero on the axis, a bit like drill bits, but the ability to plunge cut without a pilot hole speeds jobs up and makes 'em worth having.
Dave H (the other one)
Hukshawn
Nov 19, 2016
755
Likes
474
#8
They're all dull and caked in aluminum. I have no ability to sharpen them. There were a bunch of mills I tossed cause they're dull. A big rougher too. All burnt out
Hukshawn
Nov 19, 2016
755
Likes
474
#9
I'll fish them out. If someone wants them, just pay for shipping. I'll post a picture later
akajun
Swarf
Registered Member
May 29, 2017
3
Likes
1
#11
I found a few of those in some dull endmills that I was given. Discovered them when I was sharpening endmills. They sharped easy enough, but you can not "correct the grind" as someone suggested as the helix is off center. The sharpened ones seem to cut ok.
EmilioG
Jul 20, 2014
962
Likes
333
#12
You can always grind them into V cutters and single point countersinks. You can always use them for practice.
Container Above bottom breadcrumb
