- Sep 7, 2012
- 64
While working on a part this afternoon the cross slide became stiffer and stiffer. I finally had to stop and pull things all the way apart.
I found that the "bearing" surface is just a slip fit between the pot metal support and the steel lead screw. I found that the lead screw had pulled a little wad of metal from the support out and then smeared it around the opening, binding the lead screw.
Cleaning it and lubing it should get me going again for a while. Should I try to put some sort of slip layer, washer?, between the shoulder of the lead screw and the support bracket?
I have seen a couple of sites with ideas for a whole new support and lead screw. That may be down the line a bit but not right now.
Thanks, Dale:think1:
